Motronic 4.4 immobilizer
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Up to '99 immobiliser reads the code from the key and just sends OK signal to ecu.
Basically....key communicates ONLY with immo2 box and then immo2 box sends OK signal to ecu.
Key(chip in it) is only married to immo2 box module.
That said...up to '99 you can swap ecu since it's not married to the car.
BUT....you will need ecu with the same BOSCH numbers because of software difference with M4.4 management.
Late 850 like mine also have M4.4 from the factory,but it's non-turbo.
You will need ecu from LPT 850 with M4.4 or from '97 & '98 s,v70 for LPT engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
radek93
- Year and Model: S70 98
- Has thanked: 2 times
- Been thanked: 3 times
Approx. So all I have to do is buy a computer with b5254t and it should work?misha wrote: 05 Mar 2020, 13:59 Up to '99 immobiliser reads the code from the key and just sends OK signal to ecu.
- misha
Yes...but Bosch numbers from original ecu needs to be exactly the same on a replacement ecu...year too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Where are you from?
1997 850 GLT B5254T and s,v70 2.5T(B5254T) from '97 & '98 have the same engine and management(M4.4).
So...ecu swap between those two cars for EU spec.will be plug and play as long as Bosch numbers match.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
radek93
Poland. Ok. Thank You.misha wrote: 05 Mar 2020, 14:09 Where are you from?
- RickHaleParker
- Been thanked: 978 times
Look at your ECM. You will find a software number in the format "0 261 204 XXX".radek93 wrote: 05 Mar 2020, 14:03 Approx. So all I have to do is buy a computer with b5254t and it should work?
You need to find a replacement ECM with the same software number. All ten digits must match.
Active
Past
Past
- misha
That would be a Bosch part number(10-digit number).RickHaleParker wrote: 05 Mar 2020, 22:10 Look at your ECM. You will find a software number in the format "0 261 204 XXX".
Software numbers are under bar codes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
All Bosch M4.4 hardware is the same. The only difference between one Bosch M4.4 part number and another is the software. That is why the tuners call out the software version by the last three digits of the part number. Match the numbers as I outlined above and the software will match. It is that simple.misha wrote: 06 Mar 2020, 02:16That would be a Bosch part number(10-digit number).RickHaleParker wrote: 05 Mar 2020, 22:10 Look at your ECM. You will find a software number in the format "0 261 204 XXX".
Active
Past
Past
- misha
Nope.....
https://www.google.com/search?sxsrf=ALe ... ZVxo_UDmQM:
Software version is somewhere under those bar codes.
Bosch 10 digit numbers indicates just part number for ecu.
Those numbers are the same and software numbers(codes) are different.
As you can see from the picture...last 3 digits from Bosch part number (10 digits number)doesn't match with any number under the bar codes.
I have somewhere in my computer a data where exactly is softvare version,but i'm on the phone now.
I'll post it if you want to see yourself.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 4077 Views
Last post by RickHaleParker
- 36 Replies
- 9858 Views
Last post by erikv11
- 2549 Views
Last post by callahanoffroad
- 1050 Views
- 755 Views
Last post by misha
