Hello!
I had tough time removing the rotors from the front. Spent several hours of banging after PB treatment to no avail. Used the bolt method to press on the rotor to get it off. Worked! However, it seems to have pushed the "ear" of the knuckle towards inside by 2mm. So, front of the rotor is rubbing against the caliper bracket. Used 3MM steel washer as spacer between the bracket and the "ear" and it seems to be fine. I am planning to replace it with 2MM washer and also apply red loctite on the bolt for "final" assembly.
Is this okay ? Should I replace the while knuckle ?
Thanks in advance!
2012 XC60 -- Front passenger-side rotor rubbing against caliper bracket
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Please upload a photo or two.nirvana_1959 wrote: 05 Mar 2020, 17:28 Hello!
Thanks in advance!
nirvana_1959
- Year and Model: 2012 XC60
Hi BKM,
At the time of posting I had already mounted the wheel
Quick question: Since I need an offset of 1.5MM can I use a crush washer instead ? All the M14 washers come in 2.5MM thickness.
Thanks,
Anil
Thanks,
Anil
nirvana_1959
Washer solution seems to be working fine! Surprising that no info on the net on this.
- 2825 Views
Last post by regent
- 1524 Views
- 1189 Views
Last post by RickHaleParker
- 15 Replies
- 6399 Views
Last post by wizechatmgr
- 10 Replies
- 6258 Views
Last post by volvolugnut
