I'd be happy to loan you my cam locking tool if you want me to put it in a box and mail it.
BB
2001 V70XC - 200,000 Miles Makeover Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I'll complete collecting replacement parts this weekend -- exhaust vvt hub, cam seals, oil pump service kit, water pump, t-belt, s-belt, tensioners, and idler pulley -- anything missing?vtl wrote: 02 Feb 2020, 17:46
You may need to jack up engine slightly on the passenger side for the exhaust hub, the space is pretty tight there.
I don't know what is resonating exactly. Hub itself - ok, exhaust valves - not ok. What happens if you disconnect VVT solenoid? Does resonating sound go away?
My next step is collecting tools.
VTL: do I disconnect vvt solenoid for a clarity of the issue?
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Don’t forget to have a few gallons of Zerex G-05 & distilled water on hand. Your water pump bolts need sealant on them too, I use new bolts but many reuse the old ones with sealant on them.
Oil pump bolts - reuse but clean very thoroughly with solvent. I used Volvo anaerobic sealant on mine. Seal at uppermost portion of threads & under the head.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Is this Volvo anaerobic sealant (PN 30644517) same as the one used on oil pan matting surface?- Pete - wrote: 05 Mar 2020, 13:03
- - Pete -
Correct. You could probably get away with any oil/fuel proof RTV though. I used it and have no leaks several thousand miles later.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Suddenly find myself in ample free time.
xHeart
Colors of Volvo repair. I can now begin any day.
xHeart
Introduced Bauer to the beast.
- 1063 Views
Last post by chitownV
- 1226 Views
Last post by cgw4jesus
- 4058 Views
Last post by sleddriver
- 25 Replies
- 11125 Views
Last post by veektor
- 27 Replies
- 1610 Views
