2004 S60 lug bolts
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
Hi all, going to replace tires soon, wanted to get new lug bolts as the originals all look pretty bad and rusted. Is there any reason to get Volvo brand here? Looking at set of febi: https://www.fcpeuro.com/products/volvo- ... t-febi-kit
Compared to set of volvo: https://www.fcpeuro.com/products/volvo- ... t-31362432
About $100 difference. Febi is zinc plated, Volvo is chrome plated. Any other brand recommendations?
2004 S60 2.5T AWD
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
There is another option, lug nut caps. They quit using metal chrome ones due to hazardous waste residue. Chrome on plastic uses a fraction of the waste as the prep process is different. The caps are what they started using on newer models. On Amazon for 10.99 and up when I searched "19 mm chrome lug caps". The set comes with the same removal tool Volvo and others pack in their ca when they uses the caps.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Get the Febi bolts. $60 = no brainer. They aren’t an exact replica of the Volvo bolts but they are incredibly lovely! German made also. I have a picture somewhere of them on one of our cars.
How did your pocket get sticky?
Edit: I meant to say, I would avoid any 1-piece lug bolts. I’ll post a photo later.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Junkyard. Probably $1/bolt.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
jimmy57 wrote: 07 Mar 2020, 10:26 There is another option, lug nut caps. They quit using metal chrome ones due to hazardous waste residue. Chrome on plastic uses a fraction of the waste as the prep process is different. The caps are what they started using on newer models. On Amazon for 10.99 and up when I searched "19 mm chrome lug caps". The set comes with the same removal tool Volvo and others pack in their ca when they uses the caps.
Great idea. I'm ordering a set, just nut sure which color yet
Just suggest ordering 2 sets, in case a few get lost
https://www.aliexpress.com/item/3282146 ... hweb201603_
https://www.aliexpress.com/item/3302258 ... hweb201603_
- Pete -
Post by - Pete - »
One of our P2’s, well before we bought it, Discount tire convinced the previous owner it would be a good idea to replace the lug bolts with their 10-point bolts. Kinda scary. The one-piece bolts chatter, squeak and pop as you tighten them. Impossible to get an accurate torque on them.
Anyhow, I went Febi since it costs about the same to get 20 used Volvo lug bolts.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
StickyPocket
- Pete - wrote: 07 Mar 2020, 10:29 How did your pocket get sticky?
Meant to be a music thing, but can be interpretted differently i guess.
In the side by side picture - is that febi bolt, old volvo bolt, 10-point bolt?
2004 S60 2.5T AWD
- Pete -
Post by - Pete - »
Yes.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
DrDan
Year and Model: 02 V70
Been thanked: 9 times
Post by DrDan »
- Pete - wrote: 07 Mar 2020, 10:29 Edit: I meant to say, I would avoid any 1-piece lug bolts. I’ll post a photo later.
Absolutely, if you have alloy rims. Steel rims should take the one piece bolts. I keep a set of one-piece, fixed cone ones in the trunk for use with the spare wheel.
