We have a very slow leak of ATF fluid. When I say slow, I mean I don't get any drops on the ground after a drive but I do see fluid accumulating on cables that run alongside driver side of ATF pan. If I wipe the cables and edge of the pan clean, then after another drive and wipe off, I get a very small amount of fluid on a towel.
We previously replacing the o-ring on a servo cover on the driver side that was leaking and resealed the ATF pan. The leak does not appear to be coming from there.
ATF fluid is not low and shifts are fine.
Is there a weep hole on this transmission? Other than servo covers and the pan seal, are there other likely leak locations I should check?
very slow ATF leak on 1998 S90
dm635
- Year and Model: '96 965
- Been thanked: 14 times
This would be worse case. Perhaps the front trans seal.
But I think if it were that it would drip straight down between engine and trans.
And there is the shift shaft seal.
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
09-V70
05-325i
86-635CSi
thefisch
- Year and Model: 1998 S90
- Has thanked: 23 times
Following up on this, had to get the car on a lift for a couple of days after it was wiped clean to spot the leak location. There was a tiny bit of fluid seeping from the pan seal that had been done the year before. Redid the seal and no leak so far.
- RickHaleParker
- Been thanked: 978 times
Power wash clean. Add some Trace Dye to the ATF. Use a Ultraviolet Light trace the leak back to the source.
Active
Past
Past
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
The ATP AT-205 Re-Seal took care of a mystery seepage.
https://www.amazon.com/ATP-AT-205-Re-Se ... 173&sr=8-1
viewtopic.php?f=11&t=91668&p=522606#p522606
- 1902 Views
Last post by 93Regina
- 11 Replies
- 11714 Views
Last post by STSCowboy
- 19 Replies
- 3660 Views
Last post by xHeart
- 14 Replies
- 3343 Views
- 1968 Views
Last post by RickHaleParker
