1996 850 R Strange cutout with all newish ignition parts Topic is solved
Clemens
Has thanked: 473 times
Been thanked: 219 times
Re: 1996 850 R Strange cutout with all newish ignition parts
Post by Clemens »
Thanks, interesting to know. And what a perfect timing to learn more about corona. Also, there is an Italian town called Corona. Coincidence? I doubt it 😉
Now, back to business. I swapped the cap, rotor, wires and and fuel pump and injector relais from the 94 to the troublesome 96. Now it seems to work flawlessly, runs great under boost (that TME exhaust makes a noticeable difference).
What is left to do is
a) hope that it stays this way and
b) try to sort out the problematic part by swapping single parts between cars.
I will update if I can duplicate the problem in the 94 when installing all parts I removed from the 96.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Glad you sorted it out,but you should perform swapping for one item at a time.
Now....we don't actually know which item was the source of the problem.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1502 times
Been thanked: 3817 times
Buy new parts for the 1994, throw the old ones away, and go smell the 🌹
Clemens
Post by Clemens »
I will try to identify the faulty part by swapping single parts now, but I finally wanted to see results. now it is down to 5 parts, of which I will start with inspection of the fuel pump relais because 24 yrs old. then I will give the cap and rotor a shot (although just 4 yrs old).
Thanks for all your input and patience.
Summer: 1996 855 R
Donor: 1995 854 10V
Ignition,,,,,,,,,,,,ignition!
( to the tune of Fiddler on the Roof)
