Needle bearings in oil pan
- Year and Model: Lots
- Been thanked: 128 times
Needle roller bearings at inner CV joints. None in the engine.
- Been thanked: 4068 times
I don’t forget to post those cute little arrows Rick has in his post, too
( custom font or Asci codes?)
- RickHaleParker
- Been thanked: 979 times
Keyboard alt codes. It is the keyboard underworld where the ¢ key is hiding.abscate wrote: 14 Mar 2020, 04:12 I don’t forget to post those cute little arrows Rick has in his post, too
Active
Past
Past
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
`¡™£¢∞§¶•ªº–≠«‘“πøˆ¨¥†®´∑œåß∂ƒ©˙∆˚¬…æ÷≥≤µ˜∫√ç≈Ω
I don't see them.........
- RickHaleParker
↨ alt code 23 ↨
↑ alt code 24 ↑
↓ alt code 25 ↓
→ alt code 26 →
← alt code 27 ←
On the number pad, not the numbers across the top.
1. Hold down [Alt]
2. Type 25 on the number pad.
3.Release [Alt]
Some of you may need to use the number lock to get a number pad. Others hold down the function [Fn] key to get to the number pad. Still other have a dedicated numbers pad.
Active
Past
Past
Here’s how you do it in the cult of
https://www.webnots.com/option-or-alt-k ... -mac-os-x/
Rick needs to work on SA...satire awareness
- RickHaleParker
Do I need to make it more obvious¿
Active
Past
Past
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
WHOA! I just got over finding out degree symbol is available by holding the 0 down a bit longer on my Android phone. Now you're telling me I have had no cents for all these years.
Some pics of needle/roller bearings
- DSC06703.JPG (104.58 KiB) Viewed 1362 times
- DSC06707.JPG (107 KiB) Viewed 1362 times
- DSC06709.JPG (113.04 KiB) Viewed 1362 times
- DSC06715.JPG (142.22 KiB) Viewed 1362 times
Don't know if this will work. Test
- DSC06703.JPG (104.58 KiB) Viewed 1358 times
- DSC06707.JPG (107 KiB) Viewed 1358 times
- DSC06709.JPG (113.04 KiB) Viewed 1358 times
- DSC06715.JPG (142.22 KiB) Viewed 1358 times
- 1009 Views
Last post by Bero
- 12 Replies
- 2483 Views
- 25 Replies
- 11833 Views
Last post by oragex
- 1141 Views
Last post by volvolugnut
- 1714 Views
Last post by Oly850
