2001 V70XC - 200,000 Miles Makeover Topic is solved
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I'd be happy to loan you my cam locking tool if you want me to put it in a box and mail it.
BB
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
vtl wrote: 02 Feb 2020, 17:46
You may need to jack up engine slightly on the passenger side for the exhaust hub, the space is pretty tight there.
I don't know what is resonating exactly. Hub itself - ok, exhaust valves - not ok. What happens if you disconnect VVT solenoid? Does resonating sound go away?
I'll complete collecting replacement parts this weekend -- exhaust vvt hub, cam seals, oil pump service kit, water pump, t-belt, s-belt, tensioners, and idler pulley -- anything missing?
My next step is collecting tools.
VTL: do I disconnect vvt solenoid for a clarity of the issue?
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Don’t forget to have a few gallons of Zerex G-05 & distilled water on hand. Your water pump bolts need sealant on them too, I use new bolts but many reuse the old ones with sealant on them.
Oil pump bolts - reuse but clean very thoroughly with solvent. I used Volvo anaerobic sealant on mine. Seal at uppermost portion of threads & under the head.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
xHeart wrote: 05 Mar 2020, 12:24 VTL: do I disconnect vvt solenoid for a clarity of the issue?
Correct. VVT won't advance angle.
xHeart
Post by xHeart »
- Pete - wrote: 05 Mar 2020, 13:03
Is this Volvo anaerobic sealant (PN 30644517) same as the one used on oil pan matting surface?
- Pete -
Post by - Pete - »
Correct. You could probably get away with any oil/fuel proof RTV though. I used it and have no leaks several thousand miles later.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Post by xHeart »
Suddenly find myself in ample free time.
xHeart
Post by xHeart »
Colors of Volvo repair. I can now begin any day.
- Pete -
Post by - Pete - »
I’ve got my popcorn ready.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Post by xHeart »
- Pete - wrote: 15 Mar 2020, 23:37 I’ve got my popcorn ready.
Introduced Bauer to the beast.
