Coronavirus Thread
Forum rules
ToriWhite
Year and Model: 1996 850
Has thanked: 20 times
Been thanked: 6 times
Re: Coronavirus Thread
Post by ToriWhite »
Luckily I’m in a relatively trivial, low pop county in CA - but our neighbor SF basically said “Don’t go outside unless your life depends on it” - read somewhere there’s 20+ confirmed homeless in SF.. ! I hope as interesting as things get down there, it doesn’t come up here- We’ve got our own local homeless population, too.. Everywhere in CA does these days
Has thanked: 1506 times
Been thanked: 3818 times
I can confirm there are 20 homeless people in SF.
I've never had my gas gauge so high, I paid $2.28/gallon for 93 the other night.
See June ? Its a guy thing. Never fill your tank fully in case you see gas cheaper on the way, and aways wait for the little yellow light
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
What? there is a yellow light? I've never seen it.
volvolgnut
DrJammer
Year and Model: 2000 V70XC - 195k
Post by DrJammer »
Running your tank low is 1 way to see the little yellow light. Another is to have the local mechanic replace a fuel pump and not do a new fuel level sender unit. I'd be willing to do that in a month long quarantine. It's a 2000 AWD, assuming I'd still need to drop the rear suspension to fix........or is it time to cut the flap?
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
Neil will guide you on that. Summary - if you drop a early AWD platform, you have to deal with a bunch of corroded No-longer-available suspension parts.
BlackBart
Been thanked: 884 times
Post by BlackBart »
matthew1 wrote: 17 Mar 2020, 09:11 Very interesting:
Very!
Extensive and intrusive for Americans probably.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Medically speaking, here's the best overview I've seen
Why Covid-19 is so dangerous for older adults
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 17 Mar 2020, 10:34
I try to avoid letting that light come on, but sometimes it happens. But especially now, it's best to wait for gas to get even cheaper!
abscate wrote: 17 Mar 2020, 14:50 Neil will guide you on that. Summary - if you drop a early AWD platform, you have to deal with a bunch of corroded No-longer-available suspension parts.
Yup, it can be a project, that's for sure. I've been putting it off, I need to drop the rear subframe at some point and replace my fuel pump. I was thinking about cutting the flap, but I'd rather not have a hole in my floor.
There's a way to get one side of the subframe/tank down without totally removing the subframe. The sender is part of the fuel pump assembly on the AWDs, isn't it? There's just a surge pump on the driver side, so I don't think you should need to get to that.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Took out the trash today and seen somebody had thrown away a perfectly good roll of Toilet paper. That is when I knew I was not alone in the world.
