bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
RickHaleParker wrote: 17 Mar 2020, 18:20
erikv11 wrote: 10 Mar 2020, 14:43 the only place oil and coolant can mix on a P2 is in the engine.
Compression 1 - 5: 60, 30, 0, 60, 90 PSI. Antifreeze in the crankcase, antifreeze in multiple cylinders and in charged air pipe. Got to be in the upper end.
Discovered why the kid let the let the brake calipers hang. He sold the 17" Pegasus and stuck 16" wheels on. The 16" do not clear the calipers.
Yup, that makes sense. And WOW, that's definitely got a bad head gasket! Cracked liners sound even more likely here. Time to source a new engine, I think.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
bmdubya1198 wrote: 17 Mar 2020, 19:59 Yup, that makes sense. And WOW, that's definitely got a bad head gasket! Cracked liners sound even more likely here. Time to source a new engine, I think.
Cracked Cylinder wall and a blown head gasket, possible but highly improbable.
Will find out when I pull the head.
Active
Past
bmdubya1198
RickHaleParker wrote: 17 Mar 2020, 20:30 Cracked Cylinder wall and a blown head gasket, possible but highly improbable.
Well, I'm thinking it's probably a cracked cylinder wall. Probably not both.
Either way, I'm interested to see what you find out. With those compression numbers, there was a major failure!
RickHaleParker
bmdubya1198 wrote: 17 Mar 2020, 20:33 Either way, I'm interested to see what you find out. With those compression numbers, there was a major failure!
With them numbers and #3 being zero. My biggest fear is a head warped too far out of true to repair. There are no Rs or T5s around here to pick.
Active
Past
Has thanked: 312 times
Been thanked: 818 times
Wow, he sure did a number on it.
People will usually pay a fair bit for those calipers if you decide to bail on it ...
RickHaleParker
erikv11 wrote: 17 Mar 2020, 21:43 People will usually pay a fair bit for those calipers if you decide to bail on it ...
That is my insurance. If I rebuild and recondition the calipers I could turn a profit on the calipers alone.
I seen piston kits for the R calipers somewhere.
PS: ViVA Performance S60R/V70R Brake Caliper Rebuild - Seal Kit $29.99. Pistons $25.00.
Active
Past
bmdubya1198
A part out could probably get you your money back easily, so there's that as a backup plan at least. Otherwise, I could probably get you an R head... the only problem would be shipping it.
I once shipped someone from the forums a head. The key was access to a table saw. Cut a box out of scraps of thin plywood and screwed the panels together. Also used the saw to cut large, well-fitting pieces of 2-inch blue foam board to line the inside of the box. Measure twice cut once. Can't remember how I shipped it probably UPS ground, it went to the east coast.
bmdubya1198
erikv11 wrote: 18 Mar 2020, 08:39 I once shipped someone from the forums a head. The key was access to a table saw. Cut a box out of scraps of thin plywood and screwed the panels together. Also used the saw to cut large, well-fitting pieces of 2-inch blue foam board to line the inside of the box. Measure twice cut once. Can't remember how I shipped it probably UPS ground, it went to the east coast.
Good to know! It could probably be shipped in one of those big 27 gallon totes, I think it might actually fit into one of those. FedEx or UPS would be the best option.
I remember Robert having a video on shipping transmissions, and how he had shipped an M56 like that.
RickHaleParker
erikv11 wrote: 18 Mar 2020, 08:39 Cut a box out of scraps of thin plywood and screwed the panels together.
Wood Shop instructor taught us Elmer's glue is stronger then nails, screws or the unglued wood.
Active
Past
