Thanks for the information! End is soaking in PB blastet and mineral spirits. Its all I had. Lol.
I think the previous owner had glued it with something. There was some weird clear sealant on the outside. I didnt see it on any other connection.
Either way, cleaned that off and it's still stuck.
Any tips to get lower oil line off the radiator?
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
- Has thanked: 1497 times
- Been thanked: 3810 times
Grind it off with a Dremel. My part is free to any wo/man of fine and true heart, be they friend or Sconnie.
TheOtherside
JimBee
- Has thanked: 25 times
- Been thanked: 42 times
To separate the line barb from the radiator fitting, I would lock the curvature of the line in a large vice, then use a small pipe wrench with good teeth to turn the fitting.It WILL break loose.
TheOtherside
Soaked in a bucket a PB Blaster all day. Spraying for the last 5 days. Absolutely beating the ever living piss out of it with a hammer and rubber mallet for a few hours this morning and after work.
It's not of this world... I couldnt beat it any harder if I tried.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
ITs torque you need, not impact. You need to get the tools to grab the parts you are trying to separate and twist, not smack them around.
Ill send measurements on my fittings to see if they will work
TheOtherside
Oooohh... well, I dont have any impact tools.
I'll start asking some friends for help.
Thanks guys!!!
Thanks guys!!!
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
[/quote]
I kind of thought that was what was going on here...
Many helpful suggestions have been put forth, including a possible free replacement.
[/quote]
1999 V70 GLT
1999 V70 GLT
TheOtherside
And I'm greatful for all of it and payment has been offered for free parts. Lol.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
You are a glutton for punishment, I would have cried Uncle a while back. How much you want to bet that the PO epoxied the line to the radiator rather than using new O rings? A torch might be helpful at this time...
Klaus
