98 XC-Disappointing 0-60 times: what do I do? Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
Everywhere on the internet, I see 0-60 for a 98 V70 XC as 7.7sec. I've ready a real-experience forum where some people had their stock XC go 0-60 in 7.4sec, others 7.8 sec. But in my case, it's a reason to cry because both of my 0-60 runs were 9sec and 9.3sec. That's worse than the 850 Turbo which also goes to 7.8 ish seconds. What can I do to bring my engine up to par?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- RickHaleParker
- Been thanked: 977 times
Remanufactured, flow matched, 4 port Bosch fuel injectors and new Bosch O2 sensors. A lot of people overlook fuel injectors and O2 sensors because both can age and reduce performance without tripping any trouble codes.
Active
Past
Past
- CIK7
Thank you. What's your opinion on removing cat? Not illegal in my state. Someone said it would not improve performance, someone else said it might a tiny bit it may be similar to breathing through a bottle filled with cotton.RickHaleParker wrote: 20 Mar 2020, 21:14 Remanufactured, flow matched, 4 port Bosch fuel injectors and new Bosch O2 sensors. A lot of people overlook fuel injectors and O2 sensors because both can age and reduce performance without tripping any trouble codes.
- RickHaleParker
It is illegal in your state by federal law.CIK7 wrote: 20 Mar 2020, 21:52 Thank you. What's your opinion on removing cat? Not illegal in my state.
By federal law it is illegal to remove a Catalytic converter. There are specific prohibitions against removing one and replacing it with a "test pipe". Sections 203(a)(3)(A) and (B) of the Clean Air Act of 1990.
On top of that, the rest of us would end up breathing your excessive emissions, so don't do it.
Oklahoma has been doing like Kansas. Revoking state statutes and letting federal statutes govern. Produces less legislative maintenance for the state.
Active
Past
Past
Your XC is giving away a lot of pounds to the 850 and drivetrain friction too.
The faster you try to hurry, the quicker you get to end of life,..just sayin...
- CIK7
What do you mean by the first part? I thought AWD helps 0-60 times since it gives more traction.abscate wrote: 21 Mar 2020, 02:34 Your XC is giving away a lot of pounds to the 850 and drivetrain friction too.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Well 7.8 seems a little slow for a turbo 850. A quick search seems to bare that out.
As to AWD helping with 0 - 60 times, I think you loose a bit of HP going through the additional mechanics before the power gets to the wheels. I can certainly tell you that applies to 4x4's so I would think it would here as well.
1999 V70 GLT
1999 V70 GLT
CIK7 wrote: 21 Mar 2020, 07:50What do you mean by the first part? I thought AWD helps 0-60 times since it gives more traction.abscate wrote: 21 Mar 2020, 02:34 Your XC is giving away a lot of pounds to the 850 and drivetrain friction too.
Itβs a fat puppy compared to a FWD
The Volvo speed experience
200-250 HP. Fun
250-275 Really Fun
275-300. Really Fun and expensive
>300 HP really fun , expensive , and short lived
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
If you have a spare planet in your trunk, give it to me first and then continue to pollute the one you're on on purpose. If not, don't do it!!!CIK7 wrote: 20 Mar 2020, 21:52 Thank you. What's your opinion on removing cat? Not illegal in my state.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- CIK7
Love it dude!abscate wrote: 21 Mar 2020, 16:46CIK7 wrote: 21 Mar 2020, 07:50What do you mean by the first part? I thought AWD helps 0-60 times since it gives more traction.abscate wrote: 21 Mar 2020, 02:34 Your XC is giving away a lot of pounds to the 850 and drivetrain friction too.
200-250 HP. Fun
250-275 Really Fun
- 1487 Views
Last post by darrylrobert
- 1432 Views
- 605 Views
Last post by Bruce Nussman
- 1164 Views
Last post by bobboja
- 782 Views
Last post by 93Regina
