The rear OS X should sit at about 0.5VDC while running.
The front one is complex - it is a pulsed signal corresponding the varying oxygen level in the exhaust
Volvo doesn't have a set of specs for that in Alldata at least.
I can probably measure it on the S70 later today
'99 V70 2.4 NA - O2 sensors battle
- Been thanked: 4068 times
fszczesniak
- Year and Model: V70 1999
- Has thanked: 3 times
Precat should be able to jump between 0.1 and 0.9v, but what I mean is, what onboard voltage should precat get from battery/ECU... If it won't have at least 10.5v, it won't operate correctly (source - "Hella" lambda troubleshooting website)
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I habe no clue about the O2 sensor issue, but an old coolant temp sensor can cause abnormally gigh fuel consumption. But then, you seem to have traced it down to the O2 already.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
fszczesniak
My sensor is old, but I had visually inspected it not so long ago when I installed a new coolant tank and never had any problems with engine temp readings
fszczesniak
I have noticed lately that my battery is always charging with 13.6V, even after roadtrips (the battery is new) - does it add anything to the problem?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Measure directly on alternator with multimeter,BUT after about 30 min of driving and WITHOUT turning the engine off.
Red probe on b+ and black one on alternator housing.
If there is 13.9-14.0v with headlights ON and battery terminals still shows 13.6v,you have a voltage drop.
If you have a voltage drop we will proceed in further investigation.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fszczesniak
Aye, will do and report as soon as possible
Edit: as suspected, the alternator is giving around 13,9-14V, and battery is getting 13,8V (lights ON, car driven for about 30 minutes)
fszczesniak
vida dice data - hot idle
- o2 sensor precat fixed at 0,98v
- o2 sensor postcat fixed at 0,85v
running really rich or what?
- misha
You are in accepted limits of voltage drop 0.2v....charging system is healthy.fszczesniak wrote: ...Edit: as suspected, the alternator is giving around 13,9-14V, and battery is getting 13,8V (lights ON, car driven for about 30 minutes)
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Front o2 sensor should go up & down with voltage.fszczesniak wrote: 04 Apr 2020, 14:11 vida dice data - hot idle
Do you have black smoke from the exhaust at idle?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 31 Replies
- 2712 Views
Last post by melmaclifeform
- 82 Replies
- 13424 Views
- 11759 Views
Last post by packetfire
- 10 Replies
- 3327 Views
Last post by Integrity
- 437 Views
Last post by MMT51
