Hi Everyone,
Can I put the rear struts from a 2005 XC90 into a 2004 XC70?
Ideally I am hoping the who assembly would just swap.
If not then could I swap the springs and shock absorbers?
My understanding is that I need to replace nivomats with nivomats unless I replace the springs too - is that right?
Thanks,
Jason
2004 XC70 Rear Struts/Shock Absorbers Interchange
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Hi Jason,
What part of Iowa are you in?
Are your Nivomats toast?
You can retrofit in standard XC70 shocks/springs. The top mounts are the same & the bottom mount is also the same. You could probably find complete assemblies at a junkyard. I may be able to help also.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
jbert50021
- Year and Model: XC70 2004
I am in the Cedar Rapids area, but I travel to Des Moines and the Quad Cities.
My springs are broken, at least one is. I don't know about the shock absorbers. I am not wanting to mess with the compressed springs if I can avoid it. That's why I was thinking of getting whole assemblies if I can.
I have the 2005 xc90 parts available. Do you think they would fit?
Otherwise I would put a stick with wire wrapped around it if it would work. I just need this car back on the road. Any ideas that you have would help. Is there a interchange chart somewhere?
- - Pete -
I do not believe XC90 rears will fit. They do not cross on the various parts sites, but that's not to say it hasn't been done.
How many miles are you at & have they been replaced?
Lesjofors springs (in Nivomat fitment) are rather inexpensive - $28/each.
If it was me I'd take the old ones out & just swap springs. HF spring compressors are like $25-30. I've done dozens of springs with my set. I'd be happy to help you do yours if you make it into the area.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 1419 Views
Last post by June
- 2631 Views
Last post by JimBee
- 2164 Views
Last post by volvolugnut
- 10 Replies
- 4235 Views
Last post by SvenGWK
- 1477 Views
Last post by bajascraft
