Friendly reminder to avoid Lemforder/Chinese strut top bearing mounts/plates
This topic is in the MVS Volvo Repair Database » Suspension Brands to Avoid for Volvo Cars & SUVs
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I'll try and check who made the Ford Strut Bearing for the 2008 C30 T5. Was told the C30 Strut Bearing rarely had issues due to it's design so took a chance on not buying a new set. Didn't have much noise or grit feeling. Took it apart and cleaned it with brake cleaner and a brush then repacked it. Worked well and the car is quieter.
The passenger strut had blown out before we purchased it a year and half ago so the bearing was taking a beating / thump when it hit small bumps in the road. Will install the driver's side perhaps today and see how the other side is fairing as the strut is just worn but not bottoming out.
https://www.amazon.com/CRC-05353-Brake- ... CA9222F191
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
StickyPocket wrote: 22 Mar 2020, 18:11
oragex wrote: 22 Mar 2020, 05:33 I wish people would give a long term update on these.
I had Lemforder control arms and ball joints changed on my 04 S60 actually exactly a year ago yesterday. In that time I put about 7-8k miles on it. Here are some pictures of the bushings (just getting under the car - they're still installed. Sorry for bad angles):
The rear bushing is failing - will still work for a while, but it has already plenty of cracks starting. If you lift the wheel to stretch the bushing, you will see the situation even more clearly. www.youtube.com/watch?v=P1QaJbyjr2s
Has thanked: 1611 times
Been thanked: 4071 times
I just want Pete to know we didn’t miss this. We don’t miss anything, here.
Edit: forgot semi-colon & Oxford comma
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
abscate wrote: 21 Nov 2023, 02:41 I just want Pete to know we didn’t miss this. We don’t miss anything, here.
I would expect no less! :)
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
i just installed a strut top mount bearing, $35 amazon, Febest - made in Germany.
