1997 Volvo 855 GLT Brake "Catastrophe" repair 1330273
This topic is in the MVS Volvo Repair Database » Sheared Off Brake Guide Pin - Dangerous?
dosbricks
Been thanked: 4 times
Post by dosbricks »
Does this pin actually have any value other than keeping the rotor snug to hub? Is there a purpose to orientating the wheel the same for the life of the car? This mystery of Swedish engineering needs to be probed in greater depth. :mrgreen:
Has thanked: 311 times
Been thanked: 817 times
The purpose of the pin is to keep the lug holes in the rotor aligned with the threaded ones in the hub. Otherwise the rotor can spin when you are putting on the wheel.
Lots of cars use this kind of pin, sometimes there is a hole in the wheel and sometimes not, sometimes it fits into cavities in the wheel (i.e. sometimes the wheel can go back on in any orientation).
Ben850
Been thanked: 7 times
Post by Ben850 »
erikv11 wrote:The purpose of the pin is to keep the lug holes in the rotor aligned with the threaded ones in the hub. Otherwise the rotor can spin when you are putting on the wheel.
While doing the rotors and pads on my friends Honda, I came across tapered Phillips screws as opposed to pins.
They were not about to be removed with a Phillips and I had to simply drill them to get the rotors off.
They were not missed when I installed the new rotors.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Agreed, they certainly aren't important. I just meant to clarify their actual intended purpose.
Has thanked: 1609 times
Been thanked: 4064 times
Bumped for the awesome successful extraction of a broken bolt and documentation by jreed. Also the perils of using a torque wrench on the low end of its range are exposed
The official MVS torque for these bolts is six finger pounds
+1000 mvs points for hyperbolic use of catastrophe
Added part number for the rotor guide pin to title
