Thanks, i just re tentioned the timing belt and its still wobbly, noise is less but the whole belt walks around 1mm (both directions) on all pulleys. The car has always made the noise, i assume its has been like that since ive owned the car some 4 years ago.I will fit the new Volvo belt kit and see if it fixes the problem.
Here is the Haynes manual instructions for tensioning the belt..is anti clockwise turning the allen key to the right correct?
Walking timing belt
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
- Been thanked: 978 times
Just turn the Allen so the the pointer moves to the right. You will figure it out real quick because you got to turn it the other way to get the belt on.
Active
Past
Past
Perhaps making it clearer, you set the final position of the pointer
for the โ tighter โ side, not the โ loose โ side
- darrylrobert
Ok thanks, something is definitely wrong with my tensioner as when i turn the allen key the pointer moves in the same direction. I had a look at the new tensioner i have and its operation appears different. I think i will fast track this on my repair list for this car.
- 10644 Views
Last post by vtl
- 1533 Views
Last post by oragex
- 9 Replies
- 5717 Views
- 1129 Views
Last post by Volvebaker
- 5264 Views
Last post by jimmy57
