So at fairly low speed (5-10mph) i was side swiped by a CRV. It left a healthy dent in the rear drivers side door, and pushed my wagon a short distance before stopping (5 or so feet probably).
My vehicle cranks, starts, and shifts just fine as far as i can tell, yet when i shift from park to other gears the car doesn't move at all. Furthermore, when i shift from P to D i hear a temporory bearing/gear type noise something similar to what you might hear when mis-shifting on a manual transmission.
Any thoughts on what it might be? Keep in mind that nothing even close to engine bay/tranny suffered any direct impact --> any visible damage was totally limited to the rear drivers door. I dropped it off to my mechanic who guesses (before proper diagnoses) it is a damaged front axle, but what are your thoughts?
Thank you very much.
My 850 Turbo wagon was side swiped, now won't move.
- Has thanked: 2200 times
It may have dislodged on of the axles from the transmission. It is most likely the LH/driver's side one.
Did the front fender or wheel get hit in the process?
- Has thanked: 311 times
- Been thanked: 817 times
Sounds like it got pushed sideways to the right. Left front wheel dragging on the pavement may have popped out the LH axle. In that case I might expect control arm damage too, not sure how you can pop the axle without dislodging the control arm.
Or, "What Neil said."
Nick777
- Year and Model: 1995 850
- Been thanked: 3 times
Thanks for the replies.
Absolutely no visible fender damage or wheel damage of any kind.
Hey here's a thought to add to your thoughts. Is it likely the damage wasnt impact damage but "dragging" damage? When my car was dragged the short distance it was (and keep in mind it was dragged in a somewhat Diagonal / jacknife fashion) the tremendous friction of the dragging tire pulling on the suspension components and axle is what did the damage -does that make sense?
I would guess lower control arm damage and possible a new/used axle needed
$200 in parts
$200 in parts
Yes - as per the post right above yours. Control arm and/or subframe would be damaged, good chance the axle is fine just dislodged.Nick777 wrote: 24 Mar 2020, 17:38 Hey here's a thought to add to your thoughts. Is it likely the damage wasnt impact damage but "dragging" damage? When my car was dragged the short distance it was (and keep in mind it was dragged in a somewhat Diagonal / jacknife fashion) the tremendous friction of the dragging tire pulling on the suspension components and axle is what did the damage -does that make sense?
Nick777
Goodness you're 100 percent correct and I just realized that. I wasnt trying to take credit for your input erikv. I'm chronically sleep deprived and its been a really trying day, so im not exactly thinking as clearly as I otherwise would.
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Whenever I want to steal someone's insight and take credit for it, erikv is one of my top choices.Nick777 wrote: 24 Mar 2020, 22:24 Goodness you're 100 percent correct and I just realized that. I wasnt trying to take credit for your input erikv. I'm chronically sleep deprived and its been a really trying day, so im not exactly thinking as clearly as I otherwise would.
When Chrysler designed the Omni/Horizon and it was virtually identical to the VW Golf/Rabbit, I always gave them credit for stealing only the best design available to be stolen at the time. It speaks well of you for stealing only the best.
All U.S. market models.
All running and on the road.
Nick777
Eddystone, at least my subconscious thieving instincts choose, as you say, the best eh?.Lol.
Thanks scot, erik, and abscate. It was indeed the axle with the lower control arm being ok fortunately. Replacement and she's good as new (almost, but im going to generate a second thread for that).
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
If there is an insurance claim involved and you get grief over it, reach out by PM. I am well versed in NJ auto claims, but in the interest of full disclosure, my experience relates to adjusting a total loss.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
