Strange.
Usually...when it will not crank in "P" because of dirty contacts in p'n'p switch....it cranks in "N" without problems.
'99 V70 FWD, Auto, Base, 235K miles -- Toasted PNP? Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Which is suggestive that PNP switch is probably not the problem.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1613 times
- Been thanked: 4078 times
E Showell wrote: 27 Mar 2020, 07:48 Which is suggestive that PNP switch is probably not the problem.
I would read that as still a possibility , and the remote starter terminal would basically nail it. If it won’t crank on that terminal, but will if you apply voltage to the spade terminal on the starter, it’s the PNP
- E Showell
I'm still fuzzy on the remote starter terminal and associated procedure.
'95 855 auto (sold)
'95 855 auto (sold)
Put it in park and then touch a wire from the terminal to the battery B+
This bypasses the ignition switch and the starter relay
- RickHaleParker
- Been thanked: 980 times
17/1 = Remote starter terminal.E Showell wrote: 27 Mar 2020, 09:26 I'm still fuzzy on the remote starter terminal and associated procedure.
2/35 = Starter relay.
3/71 = PNP.
6/25 = Starter motor.
Active
Past
Past
Can a Vida expertises Remind me what market MSA is?
Those diagrams are horrible when they do that.
- E Showell
Sorry guys, I appreciate the numbers and diagrams, but they are incomprehensible to me. Now, if the technique could be gleaned from Keats, Milton, Byron I'd be Ok.
'95 855 auto (sold)
'95 855 auto (sold)
I bumped the remote starter terminal thread with pictures.
Make sure the car is in park
Key to position 2, on, nomcranking.
Touch a piece of wire from the B+ terminal inboard, to the connector In the white housing in the picture.
This should make the car crank and start
- E Showell
Thanks Steve. Car fired right up with a jumper wire. Diagnosis seems to be original ignition switch has given up the ghost at 235 K miles.
'95 855 auto (sold)
'95 855 auto (sold)
- 17 Replies
- 3758 Views
- 698 Views
Last post by mayorpeoria
- 139 Views
Last post by misha
- 921 Views
Last post by oragex
- 207 Views
Last post by E Showell
