Say no to Rain-X windshield washer fluid ?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It's possible the formula is different between the game of X-rain fluids. I have now been using a Rain-X deicer All Season -45C (-49F) sold in Canada, for the past two years without problems. It's a dark orange color. It's excellent in very cold winter days at start up when the windshield is still cold, about the only fluid that doesn't completely freeze up and obstruct the view.
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
I gotta weigh in on Rain-X.
The stuff was given to me by a guy for whom I did a clear and unprevoked favor. He praised it to no end.
I agree.
I've given people Rain-X treatments for Christmas. It's magic.
After taking my first look at a Rain-X washer fluid jug I thought, "This is unnecessary". I never gave it a thought after that.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
being from Australia i learned the hard way never to use windshield fluid before windscreen and fluid had warmed up?...also putting bottled water on windscreen attempting to remove ice massive failure.
2001 XC70 factory M58
2002 XC70 auto (parts car)
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
- Pete - wrote: 28 Mar 2020, 14:38
This ceramic coating is one of my favorite products. It lasts far longer than any other detailing product I’ve tried. What’s even cooler than that is how easy it is to apply. Only drawback is you need to use your own spray bottle. Effects on front glass are similar to rain-x, maybe not quite as hydrophobic. Car looks incredibly clean even after driving in rain & then drying.
Less is more with this detailer. I try to do it with the car still wet. Spray while wet, then dry as you normally would.
https://www.amazon.com/gp/product/B07N8 ... E1FZ&psc=1
Thanks Pete, this stuff works great and just as you described! Gives more depth to the shine. Son did a phone video of the hydrophobic properties but I couldn't load it so here are a few Print Screen shots. He said it was the same with the hood. Water just glides off and pretty much disappear.
He used it on his 08 C30 and the shine was blinding due to the reflection. The picks are of the 03 GS300. Number 1 for cost and ease of use!
GS300 1.png (1.2 MiB) Viewed 1078 times
GS300 2.png (1.21 MiB) Viewed 1078 times
GS300 4.png (1.11 MiB) Viewed 1078 times
Started to use magic eraser on leather and car exterior. Normal washing first and then light soapy water with eraser, rinse and seal.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I thought Magic Eraser wasn't for smooth, shiny surfaces.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
MoVolvos
Post by MoVolvos »
MoVolvos wrote: 07 Aug 2020, 16:13
Still using this product and a gallon lasted almost 5 years. As Pete said, less is more with this product. For the exterior it is best to use it as a drying aid. Use a leaf blower first and just spray sparingly and wipe. No muscles needed as the towel will just glide per video. Works on the entire car, chrome, plastic, glass and will not leave any residue like car wax in all the nooks and crannies.
E Showell wrote: 13 Aug 2020, 15:55 I thought Magic Eraser wasn't for smooth, shiny surfaces.
The Magic Eraser is ultra fine and pulls rather than scratch things off. I couldn't find the link where it attributed the Japanese for discovering the pad.
https://en.wikipedia.org/wiki/Melamine_foam
In 1984, BASF launched the first commercially produced melamine resin foam, Basotect, which was originally marketed as a flame-retardant solution for soundproofing and thermal insulation in construction.[1]
In the early 21st century, it was discovered that melamine foam is an effective abrasive cleaner and the first Mr. Clean Magic Eraser was released in 2003.[4][5][6] Rubbing with a slightly moistened foam may remove otherwise "uncleanable" external markings from surfaces. For example, melamine foam can remove crayon, marker pen, and grease from painted walls and wood finishings, plastic-adhering paints from treated wooden tables, and adhesive residue and grime from hubcaps.[7] If the surface being cleaned is not sufficiently hard, it may be finely scratched by the melamine material. Similarly to a pencil eraser, the foam wears away during use, leaving behind a slight residue which can be rinsed off.
TEC582 CERAMIC DETAIL SPRAY (1 Gallon)
https://www.amazon.com/gp/product/B07N8 ... 490B&psc=1
