bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
The dreary rainy weather has returned today unfortunately... I was just getting used to the sunny 80 degree weather we've had the past few days!
Time to get the X3 into the garage and figure out the idle issues...
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Went to a pick n pull with a 98' and 00' s/v70 and pulled a passenger door lock and swapped it in, so after 7 months of ownership my car now has 4 working locks lol. Also pulled some front brake dust shields that were in surprisingly good shape and i might go back for the rear ones.
My wipers only work on speeds 2&3 so i tried swapping in a stalk, but it didn't change anything so I have to try something else.
07 V50 T5 AWD M66 ~146k miles
bmdubya1198
Probably the relay for the intermittent wipers if that's what isn't working.
smacknab
Post by smacknab »
bmdubya1198 wrote: 31 Mar 2020, 13:20 Probably the relay for the intermittent wipers if that's what isn't working.
I tried swapping in one of the VW intermittent relays awhile ago and it didn't change anything. Just pulled the cowl and checked the wiring and also no clear issues there.
The wipers also aren't parking, and I've seen a note that that could indicate the wiper motor?
bmdubya1198
smacknab wrote: 31 Mar 2020, 14:02
Ahh, yeah that's possible. I've never dealt with it, but I wouldn't be surprised if the motor is bad. Assuming the 850 motor is the same, let me know if you need one.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
smacknab wrote: 31 Mar 2020, 14:02 The wipers also aren't parking, and I've seen a note that that could indicate the wiper motor?
Some parts of the wiper transmission are plastic and can break. Grab a hold of the wiper arm and see if it is floating.
Active
Past
JerseyVince
Year and Model: 2006 V50 T5 AWD
Post by JerseyVince »
I installed a new shifter gate blind. The original one cracked into three pieces and I was worried that dust and stuff might fall inside the shifter. To replace it, you have to remove the center control panel which covers the shifter also. It was a breeze. There's 2 bolts on top and two just behind the cigarette lighter bezel. The radio display unit just popped right out. The shift knob came off easily; just push the ring on the bottom down and the knob pulls right off. The shifter cover was a little delicate and I was lucky none of the retaining clips broke. Once the shifter cover was off, the blind just lifted right off. It was an easy job: probably took me about 45 minutes.
The blind was broken under the shifter rod.  Lookin fresh now  !
smacknab
Post by smacknab »
bmdubya1198 wrote: 31 Mar 2020, 16:51 Ahh, yeah that's possible. I've never dealt with it, but I wouldn't be surprised if the motor is bad. Assuming the 850 motor is the same, let me know if you need one.
Looks like the motors are for the 70 series only, thank you though!
RickHaleParker wrote: 31 Mar 2020, 17:23
not sure I full grasp what floating would mean, but i'll give it a closer inspection tomorrow! If little plastic bits are broken, it probably still has to be replaced, no?
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I changed the brake master cylinder on my S70. I've had funky brakes on it for years now but always kept neglecting it. I haven't been able to test drive yet since the brake bleeder assistant went to bed.
BMW 540i 2002
S70 Base 2000
bmdubya1198
smacknab wrote: 31 Mar 2020, 20:01 Looks like the motors are for the 70 series only, thank you though!
Any time!
Floating as in there's no resistance from the motor. If you grab onto the wiper and you're able to move it freely, it could be those broken plastic pieces.
