Now that I have a ton of time on my hands, I am looking to get my '95 Turbo back on the road. I love this car; it took an absolute *BEATING* for close to a year before giving out due to neglect. Long story short, the vehicle started having oil pressure problems and it threw a rod thru the front of the block right by the PCV oil trap. Before that happened there were constant oil leaks seemingly coming from everywhere. Oil starvation killed the motor, so at this time I'm currently looking for a new block that I can rebuild and drop in.
I'll document my trials and tribulations here for your entertainment. I've never rebuilt or swapped or even pulled an engine myself before; the most complicated thing I've done is a PCV job on my current 1996 Volvo 850 NA daily driver which took me an entire Saturday. Feel free to post encouragement, discouragement, sage wisdom etc. What other compatible vehicles should I be looking at when sourcing an engine?
1995 Volvo 850 Turbo (Noob Tries to Bring Her Back to Life)
humanlover
- Year and Model: 1996 850 NA
- Has thanked: 311 times
- Been thanked: 817 times
Looking forward to it!
For engines, the easiest is to look at 95-97 850s and 98 S/C/C70 cars, any turbo model. Here's the easy list:
The same HPT engine: 95-96 turbo, 97-98 HPT
Also compatible: 97-98 LPT (the GLT model cars)
Any 95-98 R model is just a regular HPT engine, if you run across that. The LPT engines can drop straight in to your car, just keep your current ECU and fuel injectors. Your intake manifold may need to be kept if you have EGR.
You can do more complicated things too during an engine swap, like change the emissions equipment (dump EGR and/or air pump) or move to a later year engine, but those require small modifications.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I have a 5spd 95 GLT wagon I'm using for a donor car for a manual swap. Motor needs rebuilt but is all there.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
95 GLT engine is unfortunately NA, not useful to OP.
humanlover
I've been waiting for a compatible block for close to a year now haha. Not giving up tho! As soon as one comes up I am locked and loaded, ready to respond with cash money to get my project started. My search radius includes Austin, San Marcos, San Antonio, Waco, etc. Basically central Texas, if there is a rear ended or otherwise trashed 850 Turbo I am probably willing to go get that block!
In the meantime here is my current daily driver: a 1996 Volvo 850 NA that is the beneficiary of all the harsh lessons I learned while absolutely abusing her 850 Turbo predecessor. As you can see she is borrowing the wheels off my Turbo. The only "upgrade" I'm interested in at this point is a Prancing Moose decal! My goal is to get her to 500k miles, maybe even more depending on how she holds up! As it stands she is SOLID. Major problems: the AC has gone out (who cares) and she needs a head gasket replacement. She's losing coolant however she just recently stopped losing oil after I completed the PCV job, which is what I was *hoping* for but wasn't exactly expecting...kinda weird by hey I'm not gonna complain. I keep a close eye on her coolant/oil levels daily but I haven't really been driving much due to the Corona situation. She starts right up everytime, never acts up, gets me everywhere I need to go.
humanlover
Can you guys smarten me up on what concerns I should have with trying to drop in a '99 S70 T5 motor? At first glance it's hard to tell what incompatibilities exist so I was just wondering if any seasoned vets would attempt such a thing.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'93-'98 YES...direct swap but keep your manifolds.
'99 or '00 NO....modifications needed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2202 times
Hey misha, why not a 99? I obviously know there are differences like the intake and exhaust mifolds, the oil cooler and 99- have VVT. But other than the move from hydraulic to manual tensioner on the timing, are the blocks not compatible? I had a friend fit a 04 S60 turbo motor into his 98 V70 AWD. Said it was fairly straight forward. You are 100% right that an earlier motor is easier as less to change.
- misha
Coil packs Neil....'98 still have cap & rotor.
Then...throttle body...etc.
That's why i said that it will require modifications.
'99 is not impossible to adapt....but he need to know what he is doing and what to modify.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 29 Replies
- 6831 Views
Last post by wizechatmgr
- 33 Replies
- 9671 Views
- 774 Views
Last post by q1t
- 22 Replies
- 3439 Views
Last post by BEJinFbk
- 1525 Views
Last post by mark0006
