What tool do I need to remove power steering pump belt - 06 XC90 2.5T
bfry
Year and Model: 2006 XC90 2.5T AWD
Has thanked: 31 times
Post by bfry »
2006 Volvo XC90 2.5T AWD
Started out as replacing the thermostat and engine coolant sensor - discovered I cannot (at least pretty sure I can't) replace the engine coolant sensor without removing the "lower body" on the thermostat housing and to get at the "lower housing" I will need to remove the power steering pump which when I looked closer actually has a pretty good leak - so now I'm going to do both - thermostat and PS pump.
Watched/read a bunch of stuff online and it doesn't seem too bad, I'm just at a loss as to what tool I will need to loosen the tension on the power steering pump belt to eventually remove it. Do I need to buy a specific tool or can I use something common?
Thank you in advance!
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
bfry wrote: 01 Apr 2020, 21:06 I'm just at a loss as to what tool I will need to loosen the tension on the power steering pump belt to eventually remove it. Do I need to buy a specific tool or can I use something common?
T60 Torx bit and a long ratchet.
If you need more room on the top and have the ECM tool. You can remove the top cover and sides of the ECM box. Then remove the ECM and TCM. If you do this make sure the negative battery cable is disconnected before pulling the ECM and TCM. When reconnecting battery, first turn key to POS II then reconnect battery. Reconnect battery after reinstalling ECM and TCM.
Active
Past
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
It's "pretty good" quality. KTC-VOL1268
bfry
Post by bfry »
Awesome - thank you guys!
RickHaleParker
wanderdüne wrote: 02 Apr 2020, 10:10 I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
For $13.95 one could get a 13 pcs set of Torx security bits with sizes up to T60.
For $32.95 one could could get a 3 pcs Extendable Ratchet set.
$13.95 + $32.95 = $46.90.
$46.90 - $34.99 = $11.91.
For $11.91 more one could get some tools will do the job the specialized tool does and a lot more.
Active
Past
wanderdüne
RickHaleParker wrote: 02 Apr 2020, 12:42
But I have a job :) And several Volvo's in the family. Not sure why I'd want to buy marginal tools to fumble around with the job when I can buy a purpose-built tool that works great and without interference for the 3 different styles of Volvo tensioners.
