Problem RPM drops out around 2-300RPM when pedal is lightly pressed, mildly annoying. Car almost stalls and also can be felt at low speeds. My first thought was the ETM being a 2001 vehicle, however i am reading many symptoms of a bad ETM an none mention RPM drops.
Could it be the gas pedal?
I have a spare gas pedal from my auto (brushless) but its different to the manual (brushed) (wires are same colours)
Ive given the brushes and tracks a noticable cleaning but problem remains
Question are the pedals coded to vehicle?
If i swap will i damage the ecm, ??
Gas pedal swapability RPM dropping out Topic is solved
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
- darrylrobert
havent test driven the car yet but swapped pedals and car appears to idle better and engine seems to respond better.
- Been thanked: 4068 times
What were the part numbers of the pedals you swapped?
Volvo web store has fitment guides that are pretty reliable for determining parts compatibility and supercessions
- darrylrobert
Brushless pedal has this written on it 30606006, 6PV 00853702. brushed pedal 9157553.
note this is a RHD vehicle, it appears there maybe LHD RHD variations
- darrylrobert
Just back from a short test drive and can report a noticeable improvement in idle, i have an IPD poly upper mount so i can feel everything, i can shuffle forward and back without stalling. Not sure what years got this brush contact pedal but worth a look at if your vehicle is playing up.
Note the connector is needed for changeover
- 4479 Views
Last post by jpeter
- 1213 Views
Last post by Captain_Hook
- 505 Views
Last post by volvolugnut
- 799 Views
Last post by Arwing
- 955 Views
Last post by arvik
