Its time to get these documented out there for all to see.
Not limited to Volvo cars - anything automotive is fair game.
Usual MVS rules - Safe for work, no objectifying images, HR approved.
"If you have to ask if its insensitive, it is."
Rating system
1. Doh! - Mistake
B. Doh! Doh! Mistake in costly time and materials
(iii) Doh! Doh! Doh! Special Mistake Worth of more than just (B.)
The great P80 Volvo Bloopers - Idiots - Fails thread - June 2023
- Been thanked: 4069 times
- 69880BCD-80B2-4145-9E3B-B8372955D7EE.png (94.63 KiB) Viewed 17041 times
This happens when someone tells you to knock the axle shaft out of the hub with a hammer to pull of the stub axle
Cost $100 for used axle
DOH! DOH!
DOH! DOH!
- Screen Shot 2020-04-03 at 8.17.33 AM.png (235.03 KiB) Viewed 17241 times
Early paid work. $100 an hour for rear axle work, can't remember what for.
2 months later, ABS light for failed right rear sensor - what could possibly be the cause??
DOH DOH for parts and labor!!
- Screen Shot 2020-04-03 at 8.17.53 AM.png (884.58 KiB) Viewed 17240 times
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
An old Ford Escord was towed to me with "no start" complaint. I found an antifreeze in tank and gas in radiator. WTF??? Owner tried to repair his bone shaker himself and mixed up fuel and coolant hoses on single point injection unit...
I dismantled tank to wash it and found this... Fuel pump was glued from two other using an epoxy.
Doh! DOH!! DOH!!!
Doh! DOH!! DOH!!!
If my English is bad, please correct me
- Has thanked: 987 times
- Been thanked: 1076 times
Thanks to all for self confession of errors.
My own mistake - MANY years ago I tried to carry gasoline in a styrafoam cup. The cup dissolved.
Duh!
Duh!
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
I once completed a rotor and brake pad swap change and left the 5 gallon pale that the caliper was resting on underneath the car. When I started lowering the car when done, I heard a crunching sound and almost destroyed my windshield washing reservoir.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
Richard99
Even better:
I once completed a replacement of a wheel bearing and forgot to tighten down the strut to knuckle bolts to proper spec. A few months later, I was getting bad wear to the outside of my wheel. I took it in for an alignment, and they called saying I needed a wheel bearing replaced. I complained how that's impossible because I just changed it and asked them to show me why they thought that. They indeed showed me the play at the 6 an 12 position but I said I wanted to just take the car back and inspect it myself. When I got home, it took me 5 minutes to figure out that the play was coming from the strut to knuckle connection. Yikes!
Lesson: Use new bolts and double check that everything is tightened down to spec!
Eric
2000 Volvo V70XC
2000 Volvo V70XC
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I joined the forum in Jan 2012. Had cleared the garage a little to work on 98 S70 T5. In November the garage was still clear so helped a friend sell his brother in laws 2005 Caravan with 65K miles. It was pretty dirty and greasy as it was used for their restaurant to haul things and make deliveries. I knew it had potential to sell as the transmission was in great shape and body was clean.
The Bad: Backed the van into the garage and after detailing left the rear hatch up and drove it out that way. Could wait to get it out into the sun to see the shine. Put a nice scratch on the rear hatch but took out the rear glass and twisted the tin can non-insulated garage door. Glass everywhere and garage hanging down twisted
The Good: His brother in laws insurance paid for a new garage door (money went to my brother, his home) and I was able to bend it back and do some sheet metal work besides bracing it with a few pieces of wood to lessen the kinks so you couldn't tell from the street. The insurance paid for a new rear hatch and glass but just installed the glass at very reasonable price. Sold it to a family of Caravan owners that use them as taxis so they were very happy with a well running, low mileage and very clean van. They decided to give it the daughter as she just had a baby. Friend was happy he got a good price and insurance money that he gave me $1,000 for the effort. The van sold for $5,488 and he still had insurance money left over.
- RickHaleParker
- Been thanked: 979 times
I had 1978 Pontiac Trans Am. Date was driving. I start sweet talking her. She likes it. Leans right to hear more. Pulls steering wheel right, car up on sidewalk, wraps it around a telephone pole. Lesson learned, don't sweet talk when they are driving.
Active
Past
Past
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I once replaced an ignition switch because I kept having intermittent problems with the car dying. All troubleshooting pointed there, with exception of one small thing I overlooked.
The battery terminal was tight and making great contact - great. The battery terminal's auxiliary feed that goes to the fuse box wasn't tight. That sucker is now double-nutted and will not come off during my lifetime. I kept smelling electrical (ozone) and could never find the source prior to that.
I also had a situation ('85 VW Cabriolet) where I couldn't for the life of me get the exhaust manifold bolts off after a shop had worked on it years before. It turns out they used regular steel nuts, not ones that were either copper coated or brass so they fused. I now use brass nuts on anything hot that I may need to be able to remove.
- 68 Replies
- 47962 Views
Last post by bmdubya1198
- 2033 Views
Last post by kippster41493
- 31 Replies
- 13565 Views
Last post by ToriWhite
- 862 Views
- 9 Replies
- 13030 Views
