S70 SAS delete
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
Hi all, hope everyone is well and keeping busy. I'm finally catching up on some overdue maintenance issues on my 98 S70 among other things. The SAS pump has been bad for a number of years and throws a code every now and then when it tries to activate. Upon inspection all the mounts for the pump have broken off and its hanging rather precariously. I am of the opinion that I should delete as many of the failed physical components but I don't think I am going to worry about the diode procedure as I don't have the parts right now. I've found a few posts on here and on volvospeed that detail the components to be removed (not the relay and the solenoid) but will I run into any issues other than the CEL if I do this? I don't really care about the CEL as it is almost always on due to an EVAP leak that I can't be bothered to sort out.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
Been thanked: 4069 times
You just need to cap,off the manifold port so you don’t have a deadly exhaust leak
shegarty
Post by shegarty »
abscate wrote: 03 Apr 2020, 15:20 You just need to cap,off the manifold port so you don’t have a deadly exhaust leak
Yep, I read that it is the same thread size as the oil pan drain ... I think I have a spare somewhere
Send me an address if you need diodes
