Can't spin tire after tightening lug nuts after brake job
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
RickHaleParker wrote: 03 Apr 2020, 12:05
volvolugnut wrote: 03 Apr 2020, 08:17 This would limit the gap for the new discs and pads.
The rust on the lip of the piston might be what is doing it.
Zapta: Clean, file, sand the rust off the lip of the pistons and try again. Be a good idea to push the pistons back out a little to avoid damaging the seal.
Since he was able to push it back, perhaps just carefully push it out all the way to inspect and clean?
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
MoVolvos wrote: 03 Apr 2020, 12:17 Since he was able to push it back, perhaps just carefully push it out all the way to inspect and clean?
If he gets a seal kit and perhaps new pistons he could rebuild the calipers to like new. He could use a salt and vinegar bath to remove all the rust and make them look good again. A lot cheaper then $153 for the same thing.
Piston seal.
More piston seals for a lot less.
You can also find pistons, seals and full kits on eBay.
Active
Past
MoVolvos
Post by MoVolvos »
RickHaleParker wrote: 03 Apr 2020, 13:24
Piston seal.
Good info, I remember rebuilding drum brake cylinders. I will need to try the Salt and Vinegar bath on my rusty body joints also :lol:.
May need to rebuild that 03 Odyssey right rear caliper as it chew through another set of pads and rotor in a year and a half. Just as well as I didn't replace the parking brakes last time and skipped on the bleeding.
RickHaleParker
MoVolvos wrote: 03 Apr 2020, 18:55 skipped on the bleeding.
No excuse for that.
Vacume brake bleeders are going for less then $20.00 on eBay.
Active
Past
MoVolvos
Post by MoVolvos »
RickHaleParker wrote: 03 Apr 2020, 19:29
No excuse for that.
Thanks, didn't know there was a kit like that? Only seen the one where you pressurize from the top. I have this, used it a couple of times for motor oil and powersteering reservoir and fluid in the hose. Will attach a hose to it. This has no gauge but will let you know if it works well.
https://www.amazon.com/gp/product/B00LC ... UTF8&psc=1
MoVolvos
Post by MoVolvos »
No excuse for that.
Did you see something wrong with the $10 set here? I found it funny that the seller's name was "liying". At first I pronounced it Lying :lol: then quickly realize it was Li Ying.
https://www.ebay.com/itm/16-in-1-Brake- ... SwWapeb2yH
RickHaleParker
MoVolvos wrote: 03 Apr 2020, 19:53 Did you see something wrong with the $10 set here? I found it funny that the seller's name was "liying". At first I pronounced it Lying :lol: then quickly realize it was Li Ying.
I was seeing indicators it is a hijacked account or was set up to scam people. I chose to err on the side of caution.
Active
Past
MoVolvos
Post by MoVolvos »
RickHaleParker wrote: 03 Apr 2020, 20:15
So maybe the seller is Li_Ying :lol:? Glad I read this as I was just going to spend the $10. Thanks.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
zupta82 wrote: 02 Apr 2020, 17:22 Well I went to autozone and measured the rotors they had in stock. They measure 1.030. I’m gonna order some duralast golds and see what happens. Also here is a pic of the caliper, I can’t press the piston any further back with a clamp.
1.030 is thicker than 1.025. I'd worry about those calipers.
1988 Volvo 760 Turbo Wagon
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
lummert wrote: 04 Apr 2020, 17:36
1.030 is thicker than 1.250. I'd worry about those calipers.
I think you may have missed the decimal place here. 1.030 is smaller than 1.250.
