Hello!
I found a nice SC-901 HU to upgrade my audio system but it's impossible to find the amp and the wiring harness to power it !
Do you know if I can DIY one or does one of you have one in stock ?
Thanks a lot for your help !
Looking for an amp and wiring harness
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 22 times
Hi Fiodor,
I just wired up a C70 amp to the SC-901. You can buy the C70 amps on ebay if you don't have access to junkyards. I just did custom wiring for this project. There is a thread (see below) on how to do it. It isn't the most clear write-up IMO so let me know if you need any help and I'll do a more thorough write-up job and post it.
viewtopic.php?t=40830
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- Has thanked: 1836 times
- Been thanked: 1709 times
I have both, but unfortunately, they are at the back of a 10 ft x 10ft secure storage room. I won't be able to get in for the maybe 4-5 months until I can get my new garage built. Otherwise I would suggest go down the C70 amp route. Not as nice and tidy. Not sure if they come with the wiring harness though.
If you are not in a rush, I can get back to you when I can get into the storage unit and can access the stuff.
Final part would be the cost of shipping. That would make it an expensive amp unless you have to have the OE set-up.
It may be worth trying looking up parts yards in Sweden. I recall seeing several which had Volvo parts listed.
Neil
Neil
- RickHaleParker
- Been thanked: 958 times
The Volvo Dolby Prologic audio unit for the SC-901 $42.50.
SC-901 Volvo Dolby Prologic processor, Volvo part number 3533799.
As for a aftermarket amp. You would need to find one with a DIN connector input or use a DIN to RCA adapter.
Aftermarket Stereo Factory Radio Amp Amplifier interface Wire Harness Cable Plug
Is the Prologic unit the same as an amplifier? The older P80's had an amp (850's) that mounted up behind the radio. The P80's that had an amp under the passenger seat and the Prologic unit if they had the center speaker on the dash behind the radio head. I may be wrong on this....!
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
If the S/V70 car came with a center dash pad speaker the ProLogic unit mounted behind the heater core in the console area. The amp was under the passenger seat. If you have pick and pull salvage yards look for a C70 model. The 100 wattamp is inside the trunk on the left side behind a panel. You can pull cables and DIN harness from that vehicle. I always take the mounting brackets. I found another amp (don't remember the car model) mounted under the passenger seat.
I have followed other threads and recently created the speaker wire harness from the amp to the OEM center console speaker connector using an aftermarket adapter and single contact connectors. This will allow me to correct any mistakes between left and right, front and rear speaker hookups. Waiting for good weather to remove the passenger seat and mount the amp, run wires, connect fused 12v supply directly from the battery to the amp,etc.
Good Luck.
Good Luck.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- RickHaleParker
The Dolby Pro Logic unit is not a amplifier. It is a Dolby Surround Sound signal processor.
- RickHaleParker
Oh man .... I got find me one of these.
I don't really need one but I am curious if universal remote would work.
Remote control RC-825 for the SC-901.
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
So I got myself a C70 amp along with the complete wiring harness, do I need to modify it in order to add it to my v70 ?
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
