Thread rules
High mileage is about 150k or more, 250k km for our Canadian friends.
What parts came over from Sweden or Belgium and are still working faithfully today ?
P80 what's still Original on your high mileage P80?
- Been thanked: 4069 times
Now at 250k build date 11 98 in Ghent
Dome light switch
Master cylinder
Brake booster
Battery cables
Power steering pump and rack
Fuel pump and all relays
Starter motor
Ac condenser
Brake lines and cables
Abs motor but not module
All cam and engine oil seals
Valve stem seals
Water pump
Clutch and pressure plate
Dome light switch
Master cylinder
Brake booster
Battery cables
Starter motor
Ac condenser
Valve stem seals
Water pump
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
1997 VOLVO 850 NON-TURBO 4 DR SEDAN B5254FS ME4.3 FWD AW50-42
Now at 180k miles, build date 5/96 Ghent (1st owner - perhaps among the last of 850s sold in US?)
It runs on 93/94 Premium gas since day one
All interior equipment except heat exchanger and blower fan
All exterior except passenger turn signal and antenna
Floor matts, including rubber weather set
ECU and all harness
EVAP except a purge valve
Master cylinder
Brake booster
Alternator & starter motor
Power steering pump
Fuel pump, all relays, and fuel injectors
Ac condenser & compressor with bread-clip
Abs motor
Engine, all cam and engine oil seals
Oil pump and pan with PCV services at 120k
Transmission
Rims and spare
License plate
Catalytic converter
Owners manual
3rd timing belt is due at 200,000 miles
ECU and all harness
Master cylinder
Brake booster
Power steering pump
Abs motor
Transmission
Rims and spare
License plate
Catalytic converter
Owners manual
Nice, points givenOwners manual
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'99 V70 Base, FWD, Auto -- Believed Belgian-made 234K
Engine
Transmission
Brake Booster
master cylinder
ABS Module
power steering pump
all a/c components
radio
steering wheel
windshield washer pump
rear wiper arm & motor
Windshield wiper motor
window regulators
all mirrors
spare wheel
Grille
All body panels & bumper covers
All glass
Intake manifold
Exhaust manifold
owners manual
at least one original key
wheel bearings
Engine
Transmission
Brake Booster
master cylinder
ABS Module
power steering pump
all a/c components
radio
steering wheel
window regulators
all mirrors
spare wheel
Grille
All glass
Intake manifold
Exhaust manifold
owners manual
wheel bearings
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2205 times
2000 V70R 2.5l B5244T2, approx, 168k miles (273,000km).
Ignition key?
Ignition key?
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
95 non-turbo 850. 250,000 miles
This is one heck of a great challenge.
Forgive the gonzo narrative.
Still Original:
Rims/Wheels. Body panels except driver's side fender. All glass. Headlights (not bulbs), Tail Lights (the fog lights are even the original bulbs), Seats. Power windows, Power mirrors (but not heat spots). Dome light. Engine, transmission. Engine Mounts (not torque mounts). ECU. Rear Delta link control arms. Fuel Lines. Wiring. Dash (but not dash pad). AC condenser (if you don't count all the Fender picks that I used as shims). Evaporator, Expansion tank. Alternator. Power Steering Pump. Subframe. Speakers in the front. Carpet (complete with lots of antifreeze!). Door Panels! Rear view mirror. Sunvisors. Speedometer and related gauges. Air vents. The Glovebox is physically the same one, although modified.
Oh and I have the original door sticker and owners manual.
I think I have replaced everything else...
Still Original:
- Has thanked: 311 times
- Been thanked: 817 times
For the four p80 Volvos I look after the range is 145k - 285k, and they've still got original:
2/4 plastic document clips on the driver's side windshield (my favorite accessory)
1/4 firewall coolant couplers
4/8 windshield wiper squirters
15/16 factory wheel bearings
Focusing just on the V70 with 285k miles:
engine long block including valve stem seals
ground straps
intake and exhaust manifolds
transmission
all of the metal brake lines, master cylinder etc
e-brake cables but they are rusted/fused
3/4 wheel bearings (replaced a rear one by mistake - was actually a noisy brake shield)
sway bars front and rear
all interior that you can see (seats, dash, door panels etc)
window regulators (OMG so slow!)
all climate control parts except blower motor
all side window glass, tailgate glass
all wiper motors, even the stupid headlight ones that I unplugged
tail lights
ground straps
transmission
tail lights
xHeart
SAME!erikv11 wrote: 12 Apr 2020, 09:56 plastic document clips on the driver's side windshield (my favorite accessory)
- 9 Replies
- 2476 Views
- 21 Replies
- 24889 Views
Last post by oragex
- 26 Replies
- 10294 Views
Last post by wizechatmgr
- 1875 Views
Last post by rspi
- 8963 Views
Last post by djtomr941
