2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
This topic is in the MVS Volvo Repair Database » 2004 S60R -- Yamaha V8 Conversion!
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
One machine shop came back with $250.00 to install a new sleeve in cylinder #3.
Been entertaining the idea getting a B8444S from LKQ pick your part and dropping it in. S60R 4.4S :?: The 2004 S60R and the 2006 XC90 are both platform 2. It might be possible to swap the entire subframe. Upgrading the transmission to a six speed TF-80SC AWD in the process. I am estimating LKQ would want about $500.00 for the entire subframe. Thinking I could do it for under $1000.00 if it can be done.
Active
Past
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I remember reading about a guy that did that in a P2 XC70 - swapped subframes & engines for a V8 XC70. I’ll see if I can find it. I think it was out of a V8 S80.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
RickHaleParker
- Pete - wrote: 16 Apr 2020, 08:26 I remember reading about a guy that did that in a P2 XC70 - swapped subframes & engines for a V8 XC70. I’ll see if I can find it. I think it was out of a V8 S80.
Volvo XC70 V8 "Saffran" (2007)
The post is written in Belarusian I can't help but wonder if Yagger had a hand on this one.
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Amazing it fits. He could ditch that "tower" bar unless he put rigid connections
Wait, the wheels :shock:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Now that would be an interesting project! I love these V8s, and in a car smaller than an XC90 it would feel awesome. It probably wouldn't be too hard, especially if you're keeping the TF80. Biggest issue would be sorting out engine management, which shouldn't be too hard... the Denso V8 ECU sits right on top of the air box, most of the wiring is right there in the engine bay, easy (relative term on these V8s) to access.
RickHaleParker
bmdubya1198 wrote: 16 Apr 2020, 09:06 Now that would be an interesting project! I love these V8s, and in a car smaller than an XC90 it would feel awesome.
The B8444S has more power the the S60R B5254T4, 311 hp vs 300 hp. The 2004 S60R has a 5 speed AW50/51 and the engine is torque limited with the AW50/51. Eleven more hp, one more gear and unlimited torque. I think the setup would scream.
The B8444S if timing chain not timing belt.
If I could swipe the turbochargers off a Noble M600 and retrofit them ... scratch that I'm not going find a Noble M600 ripe for picking.
Active
Past
- Pete -
Post by - Pete - »
Yep, that’s the one.
I watched a Volvo FF video start to finish about a tech doing a re-engine on a T6 S80. They dropped the engine/trans out through the bottom of the car. I don’t know S80’s but I think there’s enough similar that you’d probably have to do the same with a V8.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
bmdubya1198
RickHaleParker wrote: 16 Apr 2020, 09:28 If I could swipe the turbochargers off a Noble M600 and retrofit them ... scratch that I'm not going find a Noble M600 ripe for picking.
But if for some reason you come across one... you know what to do!
RickHaleParker
- Pete - wrote: 16 Apr 2020, 09:33 I don’t know S80’s but I think there’s enough similar that you’d probably have to do the same with a V8.
The only way. A subframe cannot go up.
Active
Past
- Pete -
Post by - Pete - »
:lol:
Wise guy
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
