Car Will Only Run with MAF Unplugged
ChipmunkPizza
- Year and Model: 2001 S80
- Has thanked: 3 times
I posted previously on here about a crank/no-start issue that was remedied by unplugging the MAF. This led me to believe that the MAF was at fault, so I purchased and installed a new Bosch MAF from ipd. Unfortunately, this did not fix my issue and the car still won’t start with the MAF plugged in. With the MAF unplugged, the car will start and run, but very poorly. It’s smoking excessively, despite a compression test indicating properly functioning rings (150 psi per cylinder). If I plug the MAF in while the car is running, it will eventually die and not start up again. Any help is appreciated, thank you.
- SuperHerman
- Been thanked: 207 times
ChimpmunkPizza - sounds like you have a wiring short somewhere. If you have a VOM you can do some testing starting with the harness and going back to the fuse box. Also check your O2 sensors for short to ground.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Any update, any fault codes?
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 340 Views
Last post by dikidera
- 1501 Views
Last post by xHeart
- 497 Views
Last post by darrylrobert
- 1058 Views
Last post by erikv11
- 11 Replies
- 4840 Views
Last post by matthew1
