03 v70 non-turbo catalytic converter
Biggertuna
Year and Model: 2014 S60 T5
Has thanked: 12 times
Post by Biggertuna »
RickHaleParker wrote: 11 Apr 2020, 13:32
oragex wrote: 11 Apr 2020, 09:39 Magnaflow should be good but it's $700
Two weeks ago there where MagnaFlow 51660 on eBay for just under $500.00 ( Direct fit OEM grade for 03 V70 NA ). How they are threading at $669.78.
Bought this MagnaFlow this afternoon. Total was $460 after coupon (20%, max $50) and taxes.
https://www.oreillyauto.com/detail/b/ma ... 60/4448323
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Biggertuna wrote: 13 Apr 2020, 17:16 Bought this MagnaFlow this afternoon. Total was $460 after coupon (20%, max $50) and taxes.
That one is direct fit and OEM grade. We save you ~$1000 compared to $1400 + Taxes + Shipping.
Active
Past
Biggertuna
New cat arrived yesterday and it's about 2-3" shorter in length than the old stock cat. You guys think that's going to be a problem when I go install, or will the flex pipe extend when I attach it to the manifold?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The OEM cat is huge (and heavy). What matters is the overall length of the whole section, from flange to flange and also the flange angle at the manifold. If the flanges don't fit parallel without forcing, I would return it because the flex pipe will be under stress and start leaking after a while. Same for the bracket, has to fit correctly without putting stress on the unit. The flex pipe does not extend, but does 'bent'. Also when installing, you can push-pull the rest of the exhaust for about 1-2inches to better align, but again don't force. I would also recommend to use specific exhaust black bolts and nuts, regular silver hardware seizes quickly and it's impossible to remove months later if needed (or use antiseize) Here's a test I did on flex pipes, gives an idea about the quality
Biggertuna
Great vid and thanks for the advice. I must have placed them side by side incorrectly on primary inspection; looks like it'll be a fit with minimal force and stress.
oragex
Post by oragex »
Can you take a picture deep inside the Magnaflow flexible ? I'm curious if it has interlock liner. Its flange looks having a little different angle in the horizontal plane, hopefully it will fit properly without having to force
This is how the inner interlock looks like, from left to right goes from the best to the least solid https://vibrantperformance.com/catalog/ ... d7d60674ac
Biggertuna
Let me know if these work, or if I need to zoom in more to get what you need.
Biggertuna
As part of the cat replacement, I am going to change the downstream O2 sensor. I received it today and see there's a small tube of metallic copper colored grease. I assume this is anti seize compound to place on the O2 threads? Bosch (13767) website says it comes precoated but I shows no signs of having anything on it.
oragex
Post by oragex »
It's standard braid liner inside, that's a bit disappointing. Hopefully it will last a while but if the fitting is not perfect, these start leaking anywhere from a few months to 1-2 years. Not leaking like in making noise, but more like in leaking gases and smelling sometimes inside the car.
Yes, that's a bit of antiseize and I'd recommend using a bit on the hardware bolts as well
