no boost in 05 xc70
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
I just did the timing belt and pcv system on my wife's 05 xc70. In doing so I cleaned the throttle body and replaced the gasket. The car started, but it had a rolling idle almost stalling out. It threw a throttle code. I started it again and it was idling fine, but now is not boosting. Just sounds like a bad exhaust system with no power when accelerating and expecting the boost.. Normal driving sounds fine. Is it possible the throttle body still needs to be adapted to the system and that is why there is no turbo boost or is it more likely a vacuum leak or exhaust constriction? Still have to look at everything closer, but wanted to perhaps eliminate the throttle body.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
First thing you need to do is check all your hoses. Good chance one was dislodged and/or incorrectly placed in the wrong spot. Always check your work if you have a problem as well as any thing nearby.
Next check your vacuum hoses - starting at the turbo and going to the boost control solenoid where it should then branch off with two more hoses if I recall. Many times the hose at the turbo has disintegrated and is the cause of the problem.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
From personal experience i avoid doing multiple repairs at the same time. You need to backtrack and check all your work.
2001 XC70 factory M58
2002 XC70 auto (parts car)
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Even when you disconnect the battery the learning curve for the ECM/Network is extremely quick...regardless she should still have boost. If you have a DTC for the ETM the you need to retrace your steps in that area. Is there any messages on the cluster screen?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has thanked: 1609 times
Been thanked: 4064 times
The throttle body’s on P2s is pretty reliable. Almost any code from engine management side will inhibit boost. Its a vacuum line or electrical disconnect somewhere.
Clockboy
Post by Clockboy »
I went back and took a look at everything. When I looked at the intake pipe for the throttle body it was sort of on. Gave it a little tap and it fell off. Then I remembered putting the parts back together sort of out of sequence and having to reach and curse my way to getting it on. Obviously I did not say the right curses because it was not on. It is now and there is plenty of boost. Induction, induction, induction. Thanks to all.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
The curse words need to be uttered in the correct dialect of Swedish, as per ViDA.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
- Pete - wrote: 24 Apr 2020, 14:44 The curse words need to be uttered in the correct dialect of Swedish, as per ViDA.
Link to common Swedish swear words
https://hejsweden.com/en/swedish-swear-words/
Javla Tyskar!
