2000 S70 AWD - Seafoam "Spray" treatment
hmsky83
Year and Model: 2001 S60 & 2002 S60
Has thanked: 6 times
Post by hmsky83 »
FLXC90 wrote: 24 Apr 2020, 15:15 Seafoam will attack carbon build-up, but it will also attack oil sludge, which is what might be all that is sealing some crustier valve seals that Robert is alluding to. Also as stated, it isn't meant to clean MAFs and Throttle bodies, there are much lighter solvents especially for that. As far as seafoam in the fuel system as a preventive cleaner, it will not cause problems, but may not do a whole lot to help either. The answer you may not want to hear is, if you are drivability issues that indicate the TB, you 'll just have to suck it up, and pull it to clean it. Probably just more steps than anything else. Normally, the TB on these gave problems electronically, not mechanically, but if your car is circulating a lot of oil in the intake from blow-by or turbo seals then you may need it.
That's exactly what I ended up doing. Ended up tackling that upside down TB LoL. Honestly it's time consuming but it's doable for anyone out there that's afraid as I was. If you put your head to it you can do it, it just takes time and the right tools. I just took it apart yesterday. To get to the TB I only had to take out the fan, the turbo tube, parts of the air box and disconnect some sensors and wiring in the way. The TB was extremely bad as my gut feeling was right. Now I have everything cleaned up and have many of the wiring harnesses readdressed in new 3/8 conduit.
My delema now is whether j put it a back together today or order the PCV kit online and tackle that too since I have all this room with the TB off ? Does anyone have any tips is it really that hard I'm just not sure if I will run into any thing difficult and regret it.
2001 Volvo S60 2.4T
2002 Volvo S60
2005 Chevy Avalanche
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
If you decide to tackle the PCV, order the updated banjo bolt. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
hmsky83
Post by hmsky83 »
June wrote: 24 Apr 2020, 15:56 If you decide to tackle the PCV, order the updated banjo bolt. June
2001 Volvo S60 2.4T
2002 Volvo S60
hmsky83
Post by hmsky83 »
I guess the banjo bolt in this case is a M12 bolt 1.5 inches long that's hallow. Wow $16. There's one that's white looking for $11
2001 Volvo S60 2.4T
2002 Volvo S60
June
Post by June »
Only buy the Genuine Volvo update banjo bolt! It has a steel ball that can get loose and destroy a cylinder effectively ruining the engine. My 2004 had the old design still, so your 2001 definitely has it. Buy this part from the dealer to ensure a Genuine part. What's $20 compared to the disaster of engine failure. Research the differences if you are going to buy online as you want the updated part.
The banjo bolt allows the crankcase gasses to pass into the intake manifold. I think the ball causes it to act like a old fashioned PCV valve. June
My Volvo cars owned
1996 960 ordered
hmsky83
Post by hmsky83 »
June wrote: 24 Apr 2020, 18:00 Only buy the Genuine Volvo update banjo bolt! It has a steel ball that can get loose and destroy a cylinder effectively ruining the engine. My 2004 had the old design still, so your 2001 definitely has it. Buy this part from the dealer to ensure a Genuine part. What's $20 compared to the disaster of engine failure. Research the differences if you are going to buy online as you want the updated part.
Okay thanks I appreciate it I will look into that. So just to get it straight, the banjo bolt that doesn't have the ball that becomes loose is the updated one ?
There are seven clamps. Do you know what sizes they are ? because in those kits they include Volvo clamps that need this $22 tool just for the clamps and they don't advertise the sizes of the clamps so you can't go buy them yourself.
2001 Volvo S60 2.4T
2002 Volvo S60
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
This link should be good guide: viewtopic.php?f=1&t=28487 There will be some differences.
Opps! The link above is for P80 cars. I think you have P2.
This should be better link for P2 PCV service.
viewtopic.php?f=9&t=82460
June
Post by June »
hmsky83 wrote: 24 Apr 2020, 18:07
They all have a ball. Without it the positive pressure from the intake during boost would pass into the crankcase through the PCV box. At least it's my understanding the ball pushed to block the hole during boost then pulls back during vacuum to allow crankcase gasses to vent. So installing a empty bolt likely would cause problems. June
I am not sure about the clamps. Volvo uses those one time use clamps on a lot of hoses, can't think of the proper name, but I like them best. They never seem to leak when installed properly. So I'd use them. You sure don't want to have to go there again!
My Volvo cars owned
1996 960 ordered
hmsky83
Post by hmsky83 »
June wrote: 24 Apr 2020, 19:07
Was this close to ordering the parts for the PCV job then I got cool feet and chickened out SMH. I'm just going to put back the throttle body back on tomorrow morning and put all the parts back to normal. I stuck my phone under the manifold and snapped these pictures....not sure if there's anything that stand out ??
2001 Volvo S60 2.4T
2002 Volvo S60
