Glove Box Fix
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Heh guys;
I put a little too much pressure today while leaning across to my glove box and broke :cry: the small plastic connecting rod that helps keep the box itself up. (See Photo)
My question is once I obtain the new part how do I get access (my hand) up inside there to re-attach the new part?
Must I disassemble the whole glove box?
If anyone has had to do this, please let me know.
Thx!
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 17 times
Post by deano1 »
Did you try going thru the dash board end cap?
It's the same as the one on the drivers side for fuse panel except passenger side... looks like decent approach.
I hope that helps
Dean
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
My hand is not small and I have no memories left about any difficulties replacing this spring in 02 V70 a few years ago.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
i cant see where yours is broken, but if its the same as how mine broke, i used a zip tie/cable tie to stop it coming off the knuckle. yes by hand
2001 XC70 factory M58
2002 XC70 auto (parts car)
Mr. Detail
Sorry, my photo does not show the inner portion of the cup. I broke off one half of the inner plastic part of that cup that grips the knuckle.
The cup now has no way to grab and hold onto that knuckle. Good idea about the end cap for access. Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Those tiny tabs always break when you removed them from the metal pin. Try putting a bit of grease on the pin, otherwise this is what I did to make it work forever. Notice in the video the tips about the plastic stops and also how to close back the box and attach the damper. To replace the damper, you need to fully lower the box, to have access at the securing philips screw at the bottom of the damper
darrylrobert
plastic zip tie is much easier and quicker, does the same thing. i cut a small groove/channel so it doesnt slip off.
Mr. Detail
Just curious, is there an OEM Volvo part no. look up on this site or does someone know of one out there?
Going to the dealer just to get the 8 digit part no. is a pain.
vtl
Post by vtl »
Mr. Detail
vtl, YOU'RE THE MAN!!
