That front seal is the hard to find/ expensive part.
1/4 the cost of a new compressor
Corona bench tear down, autopsy of,a 1999 9171703 AC compressor
- Been thanked: 4063 times
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I fed some words and numbers into google and hit the button. More stuff fell out than I expected.
https://www.ackits.com/santech-compress ... 3g-dks15bh
Great find 850oldschool
The carry that front seal for $13
Sanden has bought Zexel , the OEM for P80 AC compressors , so those are the parts to source
https://www.ackits.com/compressor-shaft ... m-sp-24994
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Where exactly on the plate is the damage? Having a hard time appreciating it.
Last picture a few posts up, The surface of the swash plate has the steel hemi-spheres ride on them and a film of PAG oil, the surface hardening of the swash plate has been worn off and is abrading the base steel.ZionXIX wrote: 29 Apr 2020, 06:09 Where exactly on the plate is the damage? Having a hard time appreciating it.
THe case of the compressor is Aluminum, the swash assembly steel.
- ZionXIX
Is that the scoring on the plate surface? Had to zoom in.abscate wrote: 29 Apr 2020, 07:44Last picture a few posts up, The surface of the swash plate has the steel hemi-spheres ride on them and a film of PAG oil, the surface hardening of the swash plate has been worn off and is abrading the base steel.ZionXIX wrote: 29 Apr 2020, 06:09 Where exactly on the plate is the damage? Having a hard time appreciating it.
Thats right. You see the dull gray on the smooth side? There is some sort of hardening (N2 maybe?) that makes that surface smooth for the hemisphere balls to slide - on bout half the swash surface that hardening is worn off and the steel is getting scratched up.
THis compressor worked fine, but started growling when it was working - that was the machining off of the hardening and metal on metal sound.
Could you polish up that surface, put new seals in it, and then pay $100 to recharge and get some life out of it?
Perhaps.
I will hold this one for the next guy who needs some 1999 (maybe earlier too) internal AC compressor parts. Im going to guess the internals on these P80 compressors are the same and just the mount changed on the RN engine.
Perhaps.
- Has thanked: 987 times
- Been thanked: 1075 times
My thoughts:
Swash plate surface may have had hard chrome plating.(?)
Setup to regrind smooth I think would be hard because of the angle of the swash plate. The grinding would also open the tolerance between the spherical bearings and cause a knock.
When new condition the swash plate would be mirror finish without the concentric groove like a brake disc.
This shows the need for A/C lubricant.
850oldschool
Zexel swash plate assemblies, but no prices:
http://johnica.com/new/zexel_ac_swash_plate_assy01.html
Shipping from Taiwan might be expensive/slow.
Awesome. I might just rebuild this puppy yet.
Swash plates
Reed valves
It’s all there.
Swash plates
Reed valves
It’s all there.
