More trivia on this
Th camshaft reset valve , Volvo name for the VVT SOLENOID, modulated AT 250 hz
Hmmm
6000 rpm, is 100 revs per second crank, or 50 revs per second cam. The cam solenoid can be adjusted 5 times per cam rev atvWOT
COOL.
42 teeth on the1999 T5 cam sprocket
CVVT cutaways
- Been thanked: 4071 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Is there such a pre-tensioning/pre-loading of these hubs, when replacing the timing belt only ?
Just adding to this thread. I calculated once that to be able to adjust cam flank, that is, camshaft position , fir every firing of the cylinder the solenoid has to be controlled at at least 250 Hz, so its doing a lot of work at 6000 rpm
