How did I convince myself to do this?
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
I wanted to learn how to work on my own car.. do my own brakes, maybe swap a starter or an alternator you know? But here I am 8 months later. Constantly disassembling and reassembling what feels like the largest Lego build of my life. Still, as disheartening dealing with a 200k mile European car can be, it's been alot of fun.
07 V50 T5 AWD M66 ~146k miles
Evil MVS PEOPLE
viewtopic.php?f=1&t=56005&hilit=1999+v70+t5&start=0
Couple of places in this job crows feet wrenches are really useful.
Accumulator tightening
Office tube hard line tightening.
Caw caw caw
Seriously, no Corvid emoticons?
Caw caw caw
- Has thanked: 311 times
- Been thanked: 817 times
What I see in that photo: Extra pedal, correct shifter.
No need to complain!
I'd highly recommend taking on the dash mounts while you have it apart. That's what I'd do if I ever got up the nerve to do an evap core job.
Arenβt you sending me a Doctor to MGH with a Volvo?
Perfect stop,off at my place for an evap,dinner after potato fudge
Have a real good look at the recirc air door flap motor and plastic linkage while you have that HVAC out
If you can buy it cheap new I would replace.
They do break and are hard ( impossible?) to do in car.
- smacknab
That's exactly the little flap door that I broke when trying to get the unit out.... I'll look for a part number on the unit and see if I can find itabscate wrote: 30 Apr 2020, 04:36 Have a real good look at the recirc air door flap motor and plastic linkage while you have that HVAC out
Try 6808655
- Has thanked: 2199 times
Check the whole main flap assembly. I found it broke because the driver's side flap seal had turned to a sticky goo making it stick when closed and making more strain on the motor and flap. That is not available and has not been for many years. I had to pull on from a scrap car to get a good one. That may be a challenge with the age of the vehicles now. To replace required opening the whole heater box if I recall correctly.
Tackling the dash mounts even if they have not failed is worth doing as there is a good chance if they are not broken they will when you re-install. I think abscate had a write up on how to do that.
Good luck,
Good luck,
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Nothing to crow about. In fact you sound as if you are raven mad!abscate wrote: 29 Apr 2020, 16:28 Evil MVS PEOPLE
Caw caw caw
All U.S. market models.
All running and on the road.
Neil
- 37 Replies
- 5075 Views
Last post by wbrenegade420
- 15 Replies
- 7708 Views
Last post by wizechatmgr
- 925 Views
Last post by precopster
- 13 Replies
- 2911 Views
Last post by JRev
- 587 Views
Last post by chestermo
