automatic transmission problem
jped185
Year and Model: 1992 240
Post by jped185 »
1992 240 - Shifts from first at about 20 mph, but have to get to 50+ before it will shift to 3rd. Overdrive appears to be working correctly. What is the likely problem?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
What is the condition of transmission fluid - Pink, dark red, black? Last known fluid change with filter? Maybe a sticking shift valve?
Could start with fluid change if fluid is dark.
jped185
Post by jped185 »
Thanks for your help. Fluid is dark brown. I have never changed fluid. Will change of fluid and filter possibly "unstick" a shift valve?
It may help the shifting. However, search for failure after transmission fluid change. Sometimes a fluid change can stir all the junk in the transmission and cause total failure. What is the history on this car and transmission?
Also search this forum for transmission fluid and filter change. The filter is inside the transmission and requires removal of the pan. If you do not think you can do this, a transmission shop can change filter and fluid. Confirm the correct fluid type.
See this thread on trans fluid and filter change:
viewtopic.php?f=2&t=12415
jped185
Post by jped185 »
Vehicle has low mileage. Approx 85 to 90K but don't know for sure as the odometer quit a couple of years ago.It is my wife's second car and she rarely drives it. No problems in the past with trans, I just noticed this problem in the last month. I will do the fluid change and see what happens. Thanks again for your input.
I suggest an Italian transmission tune up after a fluid change. Drive it hard while working through all the gears. This car sits too much. Not good for any mechanical thing. If 3 speed with overdrive, then Dextron II fluid should be correct.
jped185
Post by jped185 »
I'll give it go. Will get back to you with results. Thanks, stay safe.
I am surprised no one else has commented on this issue.
