2008 V70 2.5T fault code P3388
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
samiwithvolvo wrote: 03 May 2020, 12:36 This fault seems to remain a mystery for now. After resetting the codes second time on April 6th, the engine fault indicator has stayed off and car works normally. I wonder if a bad batch of fuel could have caused the issue, dunno.
How cold is Finland in March?
Metal contracts when cold, expands when hot. It might be an air leak that only shows up when it is extremely cold.
Active
Past
samiwithvolvo
Year and Model: S60 T8 2019
Post by samiwithvolvo »
This winter was quite warm overall, but on March we were around 0 celsius, while typically on January and February we could have up to -20...-30C. Temperature is not a very likely cause on this case, but of course also not totally dismissed. We’ll see next winter if the fault does not show itself earlier. :D
