How to tell if Timing Belt Service had ever been done ? Topic is solved
- hmsky83
- Year and Model: 2001 S60 & 2002 S60
- Has thanked: 6 times
Was wondering how can I be certain if this 2nd hand vehicle I purchased has ever had a timing belt service done ? I've become more and more suspicious it has Not, to be honest. I've just parked it in the garage until I can find out more. Luckily I have another vehicle to drive. The car has 159 000 Miles so normally it would be almost due for the 2nd service but I fear it never had it's 1st either.
If I took some photos can you guys can help me make a clear conclusion. Hopefully I'm wrong but I don't think so. I'm not sure if I will do this myself or try to find an experienced Volvo Mechanic in the Seattle area, who has reasonable rates. Will be adding photos soon as I get home. Thanks in advance to everyone for the help and advice
2001 Volvo S60 2.4T
2002 Volvo S60
2005 Chevy Avalanche
2002 Volvo S60
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
There is a sticker that comes with a timing belt change kit that gets applied inside the engine bay. Some mechanics will use permanent marker inside the engine bay. If I see neither, or don't get a receipt on a used car I buy, first thing I do is a full t-belt change, water pump, tensioner, idler.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Interval for the 2001 is 105k miles/12 years. Take the timing belt cover off and have a look for markings on the belt. These belts are robust and are not to be feared for failure until well past the change point, especially if you drive them in an adult fashion I ran a 1999 for 140k miles
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
if in doubt just change it. and i see you have an old style VVT valve, change that too or remove and check it works. mine clicked like it was working but i removed it and it was seized up.I am seeing huge improvement to fuel economy.
if there is no writing on the belt its probably not new
2001 XC70 factory M58
2002 XC70 auto (parts car)
- hmsky83
Can you point out the vvt part you're saying to change / test in the picture ? Is it hard to do ?.darrylrobert wrote: 05 May 2020, 06:01 if in doubt just change it. and i see you have an old style VVT valve, change that too or remove and check it works. mine clicked like it was working but i removed it and it was seized up.I am seeing huge improvement to fuel economy.
2001 Volvo S60 2.4T
2002 Volvo S60
2002 Volvo S60
- hmsky83
Is this part what I may need ?darrylrobert wrote: 05 May 2020, 06:01 if in doubt just change it. and i see you have an old style VVT valve, change that too or remove and check it works. mine clicked like it was working but i removed it and it was seized up.I am seeing huge improvement to fuel economy.
- 114758 - Genuine Volvo - Exhaust Cam Adjustment Actuator Solenoid CVVT - 31251211
- thumbnail_4444.jpg (9.7 KiB) Viewed 3126 times
2001 Volvo S60 2.4T
2002 Volvo S60
2002 Volvo S60
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
If you go to Carfax, it has a free service that you can register for that allows you to track service history for several vehicles. It is of course dependent on the mechanic to detail that the time belt was done specifically, but I was able to verify TB service done on an XC90 I purchased last summer when the PO was unaware of the last TB service.
- hmsky83
Are you sure it's free cuz I just went to Carfax and it says it's $39 ?volvooh wrote: 05 May 2020, 06:41 If you go to Carfax, it has a free service that you can register for that allows you to track service history for several vehicles. It is of course dependent on the mechanic to detail that the time belt was done specifically, but I was able to verify TB service done on an XC90 I purchased last summer when the PO was unaware of the last TB service.
2001 Volvo S60 2.4T
2002 Volvo S60
2002 Volvo S60
- hmsky83
Thanks man !!! Checked Carfax and seen all the services done by past owners, but no luck with timing belt service SMH.hmsky83 wrote: 05 May 2020, 06:59Are you sure it's free cuz I just went to Carfax and it says it's $39 ?volvooh wrote: 05 May 2020, 06:41 If you go to Carfax, it has a free service that you can register for that allows you to track service history for several vehicles. It is of course dependent on the mechanic to detail that the time belt was done specifically, but I was able to verify TB service done on an XC90 I purchased last summer when the PO was unaware of the last TB service.
2001 Volvo S60 2.4T
2002 Volvo S60
2002 Volvo S60
- 808 Views
Last post by - Pete -
- 26 Replies
- 5026 Views
Last post by Petskoi
- 3810 Views
Last post by CIK7
- 827 Views
Last post by doublebug
- 1076 Views
Last post by Cees Klumper
