Any Volvo techs on here? re: brakes
Has thanked: 1611 times
Been thanked: 4071 times
On your 1999 the brake position sensor passes a resistance proportional to the brake pedal position directly to the ECM
1999 was the first year that the engine torque was completely managed by electronics, like all cars today.
It won’t impact Hydraulic brake operation.
It’s volvo diagram designation is 7/124
Part number is 9441116
Shappy
Year and Model: V70 1999
Has thanked: 5 times
Post by Shappy »
Thanks! But I'm still wondering what the ECM does with that information. What is its purpose?
Shappy
Post by Shappy »
And what would be the consequence of disconnecting it?
Check engine light, probably no boost ( fatal ECM failure) no cruise control ?, etc
Without knowing the ME7 source code ( which isn’t public) it’s hard to predict what ties to what in software buttorque management is complex from1999 on.
You probably will get an ABS fault too, BCM- xxxx
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I know for a fact that the brake pedal position sensor is tied in with the cruise control. Beyond that, I don't know the specifics. ME7 uses it for something, but I'm not totally sure. I have a good ME7 document somewhere, but I'd have to dig around my files.
In 1999 everything got integrated to provide torque management. Even the ac compressor is turned on by the ECM, not just a relay through the ac pressure switch anymore.
