Can't get it in the air right now to look under it, but within 2 minutes of running, there's a 3" puddle on the ground of what looks to oil.
Drivers side of the engine towards the back.
Anyone know what's there that could be leaking?
Here's a really bad picture. Of where it might be coming from.
Help identifying another leak...
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
Rear cam exhaust seal 9443310, a mere$4.03 from FCP
TheOtherside
Dang! You're quick! Lol. Thank you!
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Has thanked: 2199 times
Abscate beat me to it. I would also add, that if the PCV has not been checked in a long time, it is time for the glove test to see if it is blocked. This is the main reason for seals to start leaking is a pressurized crankcase.
TheOtherside
Perfect. I'll check! Thank you guys.
Out of the blue 2 days ago. Instantly. Crazy how it could go that quick.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
TheOtherside
The one im seeing is $25
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
That will get you a blue box Volvo.
The Corteco seal is every bit as good ( not OEM) and is on my cars
Neil’s advice on checking crankcase pressure is indeed Samurai
TheOtherside
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
TheOtherside
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Make sure everything goes back in the way it came out. That slot in the middle is asymmetric.
- 1144 Views
Last post by SuperHerman
- 7348 Views
Last post by Electronicsguy
- 34 Replies
- 4039 Views
- 1316 Views
- 1480 Views
Last post by joelq
