2001 V70XC - Rear shock bushing separating Topic is solved
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Rear Lesjofors for regular shocks do sag down quickly. Genuine Volvo does that too.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
vtl wrote: 07 May 2020, 14:10 Rear Lesjofors for regular shocks do sag down quickly. Genuine Volvo does that too.
Would Lesjofors hold better over Volvo OE shocks? What combination works best?
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I put the Lesjoförs HD springs in the rear of 2 of our XC70’s. Very noticeable difference. Rear rides about 1 finger width taller (if you put your fist between the tire & fender arch). Definitely a handling improvement. Slightly stiffer but honestly the saggy & plush stock rears are disappointing in comparison.
For my 286k mile IPD stage 1 XC70, I bought the Nivomat fitment springs a couple months ago in prep for doing VTL’s recommended rear suspension upgrade. Still coaxing myself to the edge of the cliff for the self leveling shock purchase. Then the baby Russian lift kit. The last 2 things will have to wait a little while. Been chasing a wandering boost issue & should have it solved early next week w/new ETM install.
Anyhow, the Lesjoförs HD springs are a really great improvement & very affordable. I’m using them with my original rear shocks. I will leave them be until I buy the Nivomat rear shocks.
4295844 on FCP.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Post by vtl »
What's the baby Russian lift kit?
- Pete -
Post by - Pete - »
It was the one you shared a couple weeks ago. I’ll see if I can find it.
Edit, HERE it is.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
Post by vtl »
Ah, yes. Sold out :(
xHeart
Post by xHeart »
Starting to collect parts and tools for the rear suspension service. Suplex coil spring was recommended for its quality over Lesjofors.
xHeart
Post by xHeart »
- Pete - wrote: 14 Apr 2020, 06:59
The only bolt you need to remove from the top to free the strut from the car is the one with the “half moon” shaped washer. The other 2 large bolts you remove from underneath. Once the strut is out & on the bench, get your spring compressors positioned & tighten them down until the top hat is free from tension. Then and only then can you remove the center top hat nut to replace the shock.
Rear wheels are off, and ratchet strap is installed keeping the control arm in place before loosening the bolts.
Does the rear strut assembly mounting on 2001 V70XC has the top bolt with the "half moon" shaped washer. I am not seeing any from the cargo area -- with third row-seat.
- Pete -
Post by - Pete - »
It should have it. You need to remove the “front” lift-up panel/third row seat back, then remove carpeting/noise damping insulation underneath. Then you should see some (2) gray circular foam pieces on the L & R. Pull those off and underneath you should be able to catch a glimpse of the half-moon washer & fastener heads.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Post by xHeart »
- Pete - wrote: 22 May 2020, 07:24 It should have it. You need to remove the “front” lift-up panel/third row seat back, then remove carpeting/noise damping insulation underneath. Then you should see some (2) gray circular foam pieces on the L & R. Pull those off and underneath you should be able to catch a glimpse of the half-moon washer & fastener heads.
Found it -- nicely hidden under the layers with Volvo quality. It has never been exposed.
