Stuck bolts between turbo and catalytic converter
Once you climb above 100 ft lbs, or shoulder muscle pull on a one foot bar, if you don’t clear thread friction you will break the bolt, either round the head off or snap it. Heat, lube, cold, or impact before you get to this point
Thank you all. At the end I went to a local shop since the access was very limited for me to heat with a torch (turbo is behind the engine). He was able to apply some heat, he added some lubrifiant and waited overnight. He was able to remove the screw in the morning.
- 4895 Views
Last post by MadeInJapan
- 3292 Views
Last post by ZionXIX
- 2803 Views
Last post by mkc1
- 625 Views
Last post by lummert
- 537 Views
Last post by bmncw
