S70 rear exhaust cam seal continues to leak
rnelson1020
Year and Model: 1998 S70 GLT
Post by rnelson1020 »
1998 S70 GLT with approx. 200,000 on engine. Have replaced rear exhaust cam seal at least 4 times over the past several years. It begins leaking quite soon after doing so. I have used Volvo and OEM seals. Have never replaced rear intake exhaust cam seal and there is no observable leaking. Advice or thoughts?? Car runs and handles beautifully, otherwise. Thanks.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Pcv system overdue?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Do the PCV glove test.
Active
Past
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
If it's not clear why people are asking about PCV system and the glove test it's because if the PCV system is bad, it will lead to excessive crankcase pressure which pushes on all the seals in your engine.
And if the pressure is high, your cam seal could suffer and the excess presure could be the source of the continued failures.
-A
rnelson1020
RickHaleParker wrote: 12 May 2020, 16:00 Do the PCV glove test.
Thanks. Not sure what the "glove test" is, but I'll check it out.
misha
Post by misha »
Open the hood,remove oil filler cap,put a latex glove onto the filler kneck,start the car and see if it inflates or it's being pulled down with vacuum.
If it inflates pcv system is clogged.
If not...it's ok.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
rnelson1020 wrote: 21 May 2020, 11:08 Thanks. Not sure what the "glove test" is, but I'll check it out.
You check for crankcase pressure build up by tying a latex glove to the Oil filler. It should be a vacuum that suck it glove down. Pressure will push the glove up.
Pass
Fail
Active
Past
rnelson1020
Mucho thanks. I did the glove test and it inflated. I am now in the process of renewing the PCV system. I'm also trying to remove the oil pan to check things out with oil pickup, etc. Having difficulty getting any sort of wrench, socket, etc. on the front corner passenger side bolt on the oil pan. Will try removing the wheel and fender liner for access. I keep wondering how much longer I'll keep this 1998 car going but it just doesn't seem to want to die and it just runs and drives so well, even with 270,000+ miles.
RickHaleParker
rnelson1020 wrote: 30 May 2020, 16:35 I'll keep this 1998 car going but it just doesn't seem to want to die and it just runs and drives so well, even with 270,000+ miles.
If you keep up the maintenance and repairs you got another 270,000 miles to go.
Active
Past
