SC-901 3 Disc in dash CD player Topic is solved
- subzerocarfanatic
- Year and Model: 2000 Volvo C70 HT
- Has thanked: 75 times
- Been thanked: 10 times
I tried cleaning the laser eye after sliding the magazine out like the post I found suggested. I used Isopropyl alcohol on a cotton cue tip and still the CD keeps cycling it sounds like,the disc seems to load in spot but after a few sconds it will not play and keeps recycling or trying to load over and over, any suggestions?
- Has thanked: 2210 times
That is a shame. Perhaps it is just a bad unit. Wish I was closer and I would look at the SC-901 for you. I do find that IPA can sometimes leave a film on anything you clean with it. PITA, but maybe worth another round of cleaning and follow up with a clean cotton bud to wipe any residue.
The SC-900 was known for this, but the SC-901 was not immune to this issue as well.
- RickHaleParker
- Been thanked: 980 times
Does it do it on all three disk positions?
Active
Past
Past
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 7 times
Give it one more try. Cleaning brings it back to life if laser is still in working order. I have fixed two SC-901 units this way.
- subzerocarfanatic
I have tried cleaning this again,still no luck.I can hear the disc loading,I have 2 disc in it,it will load or try loading,not sure which but it sounds like it loads but then will not play.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Stupid question but are you playing an actual CD or one you burned. I found it would do that with cd's that were of DVD format or burned as a storage disk. Mine did the same thing with cd's not burned properly
2008 S60 2.5T Auto (Sold)
- subzerocarfanatic
No they are regular CD's , not burned ones
- subzerocarfanatic
Ok everyone. I finally got the CD Player working, wow what an amazing sound system this car has,the best by far I have ever heard in factory form! I am amazed at the concert sound,if only my Pro-Logic option would work properly.
Both side rear speakers for back seat passengers cut out to low and kind of static and distorted sound when pro-logic option is chosen.
Someone mentioned a pro-logic decoder box or something, i looked behind the deck when I had the SC-901 pulled out and I see nothing at all there,where exactly is it located on the 2000 C70 Convertible?
- RickHaleParker
Behind the SC-901 head then down. Just follow the DIN cable. Which is plugged in to the back of the head.subzerocarfanatic wrote: 01 Jul 2020, 15:10 Someone mentioned a pro-logic decoder box or something, i looked behind the deck when I had the SC-901 pulled out and I see nothing at all there,where exactly is it located on the 2000 C70 Convertible?
Active
Past
Past
- subzerocarfanatic
Can anyone tell me what some of the signs are if the dolby pro-logic audio unit is going out, or what symptoms arise if it is going bad
- 1310 Views
Last post by subzerocarfanatic
- 2710 Views
Last post by okidiver
- 719 Views
Last post by sjhowardmvs
- 2916 Views
Last post by phils94850
- 1119 Views
