Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
E Showell wrote: 12 May 2020, 17:22 Texas sun must be brutal on a paint finish. On the plus side, probably not a lot of road salt to worry about.
Not in Texas, but near there. After 10-12 years the clear coat starts to deteriorate. Red colors fade quickly. Do the clear coats go bad in northern states?
jonslave
Year and Model: 1997 855R
Has thanked: 12 times
Post by jonslave »
I heard these cars didn't have a clear on them. Is that true? There isn't any peeling which you would expect.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Volvo clearcoats generally don't see the failure rates of some domestic and older Japanese models. Clearcoat's durability can have some color-based issues. Clearcoat's problems I've experienced in NJ on Volvos were due to failing crash repairs, not bad factory clearcoats.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
jonslave wrote: 12 May 2020, 19:20 I heard these cars didn't have a clear on them. Is that true? There isn't any peeling which you would expect.
Correct, 601 red is single stage. A compound job with M105 or similar will clear that paint right up.
jonslave
Post by jonslave »
Yes looking forward to getting some as seen on tv wow moments after a cut job on it. This 855R is a Houston car and lived around the gulf coast its whole life. According to the CarFax it had 72,500 miles after 3 years ownership, poor thing was stuck going straight for so long.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Bought a non leaky and working sunroof assembly to replace mine, also got a clean headliner from the donor car
I might be able to fit it this week end, but I have to change the pcv on a friends 850 first :P
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Got my freon evacuated in preparation for ac compressor replacement. While the freon machine was working, mechanic buddy sid he noticed the radiator leaking due to residue around the top. I glanced at it and decided to replace the radiator too since it was 15yrs old and the brand is unknown. After closer inspection what he was seeing was the top plastic cap of the intercooler. The top cap is soaked in oily dirt residue and Im at a loss to explain how or why. Thoughts? I havent experienced any boost issues. I suppose there could be a leak but I dont know how it could get on the front side too?
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Pulled my runner cover with an autobody friend to find this. He says it's manageable and I was hoping to get 5 years out of the car so I guess I'm tackling this next.
I'm going to check out a s70 that just arrived at junk lot to see about cutting off a donor piece. I have a thread going if anyone has any tips
07 V50 T5 AWD M66 ~146k miles
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Addressed the misfiring on the 2003 S40. Cleaning the electrical connector to the MAF is all it took.
bmdubya1198
smacknab wrote: 15 May 2020, 17:25 Pulled my runner cover with an autobody friend to find this. He says it's manageable and I was hoping to get 5 years out of the car so I guess I'm tackling this next.
:shock:
I imagine this is what my cousin's old wagon would have looked like if we removed the rocker covers before crushing it.
ZionXIX wrote: 15 May 2020, 17:01 Got my freon evacuated in preparation for ac compressor replacement. While the freon machine was working, mechanic buddy sid he noticed the radiator leaking due to residue around the top. I glanced at it and decided to replace the radiator too since it was 15yrs old and the brand is unknown. After closer inspection what he was seeing was the top plastic cap of the intercooler. The top cap is soaked in oily dirt residue and Im at a loss to explain how or why. Thoughts? I havent experienced any boost issues. I suppose there could be a leak but I dont know how it could get on the front side too?
That's relatively normal. It's probably what has soaked through the IC hoses. As long as you don't have any boost issues, I say go ahead and clean it up and run it!
