The DC motors are all the same for almost every car out there. Some have longer shaft or differing gears. Early in the year I followed the same method below and took some copper wire from the Romex and repaired the motor to the 03 S80 T6 door lock actuator.
After taking apart the Fuel Door actuator for cleaning and lubing it still did not work. There is 12V going to the wire connector. No one steals gas here so the actuator is just out till I get to the motor.
Fuel filler door won't unlock Topic is solved
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- MoVolvos
They are very inexpensive on eBay. Just have to make sure the body and shaft are the same. I think I had trouble finding the correct motor without taking it out. I also didn't want to have the door sitting unlocked with a bungie cord to the other door while figuring out and then waiting for the new motor.cn90 wrote: 12 Nov 2019, 20:13 I think the small electric motor is made by Johnson, I have seen it on ebay for a few dollars.
Geno9707
- Year and Model: 2004 s40
- Been thanked: 3 times
Geno9707 wrote: 12 Nov 2019, 19:45 Hello everyone.. I had the same issue on my 2004 v70.. I ended up replacing the fuel door lock latch solenoid here is a link where I Bought one for a great price and the video of the link how to replace it..
Fuel door lock latch Solenoid EBay
https://www.ebay.com/itm/353060135687
Yaworski
- Year and Model: 2002 S60
- Has thanked: 5 times
My V70s gas door started not unlocking. I found that if I smacked the door really hard it would unlock the next time I unlocked the doors. I cut the locking tab off the door. I'm not overly worried about someone stealing my gas.
Geno9707
Geno9707 wrote: 12 Nov 2019, 19:45 Hello everyone.. I had the same issue on my 2004 v70.. I ended up replacing the fuel door lock latch solenoid here is a link where I Bought one for a great price and the video of the link how to replace it.. 99.99% percent its the solenoid that goes bad and not so much the switch. Hope this helps you guys out.
- Been thanked: 4069 times
The good news is gas is too cheap to steal. The hose to siphon it costs more than the gas
- 2133 Views
Last post by chrism
- 1279 Views
Last post by DavidE7
- 755 Views
Last post by MarcusTeran67
- 3419 Views
- 950 Views
Last post by chefmarkt69
