Hopefully so, the solder did look like cold joints, I'll try out another cluster tomorrowRickHaleParker wrote: 12 May 2020, 18:57Cracked solder joint, path or connector got aggravated when you pulled the cluster.henrysin44 wrote: 12 May 2020, 18:49 Don't exactly know how that could cause a CEL after a week but the cluster has always acted up for years now.
94 850T check engine light while accelerating
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That cluster is bad and you will need to replace it.henrysin44 wrote: 12 May 2020, 18:49 ...Don't exactly know how that could cause a CEL after a week but the cluster has always acted up for years now.
As a side note not all the lights come up when key is in position 2, or while starting, but all are functional.
Could be a bad connector to the cluster or cold solders on the cluster.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Dumb question - Are you sure it’s the CEL?
This sounds like exactly what happens when
you get low on windshield washer fluid.
If I catch it out of the corner of my eye,
sometimes it tricks me...
- misha
That light is on the opposite side of the cluster.
However...his cluster is not working properly....just 2 or 3 lights on bulb check and all of them are replaced and checked.
It's either a connector or cluster is bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
Yesterday I replaced the knock off RPM sensor with an OEM sensor. There is no change from doing it, CEL still comes on during hard acceleration, but im glad i swapped it out, doubt the knock off would last much longer. Maybe I just need new spark plugs? Theyre coppers and im pretty sure ive been running them for at-least 10K.
As for the cluster, its not defective
. I did however figure out why the key-on lights don't come on! When the battery/charging light comes on it will also turn on most of the dash warning lights, which would also explain why the key-on lights come on if the alternator belt snaps. (pic below). So my battery light isn't getting a signal from the charging system, which doesn't bother me yet.
EDIT: The alternator signal wire was disconnected, now my dash shows all the warning lights when in position 2. Still have a CEL on acceleration though.
- misha
It should...because if the warning light doesn't work...your alternator will not have output.
The light works as "awakening" for alternator.
EDIT...i just saw that you re-connected the wire.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
How long have you been driving it since the battery disconnect?
It could clear up after the ECU readjusts a bit.
You could have a sensor that is out of spec, enough to cause an issue when the ECU is reset, but will then clear up after a while. My M4.4/green injector-swapped '97 does the same thing. It would "reset" after having the battery disconnected for a time and then would flash the CEL at me on acceleration for a few drives until clearing up.
How old is the Engine Coolant Sensor? When was the last time you checked the connector?
I think with the M4.4 ECUs that flashing on acceleration is a knock sense reaction.
Misha is much more an expert on this stuff than I am, though.
- henrysin44
That would definitely explain why my headlights would be dim until i started driving.misha wrote: 14 May 2020, 09:07 It should...because if the warning light doesn't work...your alternator will not have output.
I've drove about 150 miles total sense the reset, the coolant sensor is only about a year old and I re-did the connector wiring when I replaced the sensor.Chuck W wrote: 14 May 2020, 13:24 How long have you been driving it since the battery disconnect?
I really hope the CEL is not a reaction to a engine knock, engine sounds healthy though.
- Chuck W
I guess it's also possible that you had low voltage going to your ignition system, which could cause an issue when the engine was under load.
- misha
You had a good luck that your battery was in good shape.henrysin44 wrote: 14 May 2020, 15:55 ...That would definitely explain why my headlights would be dim until i started driving.
Since you ran a car with low voltage charging system...i would suggest to remove negative battery terminal for a few hours in order to reset car's management system and all bad things it could catch because of low voltage.
After that,perform a re-learning procedure for ecu and check voltage output on battery terminals.
Re-learning procedure:
http://www.volvotips.com/index.php/850- ... rocedures/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 789 Views
Last post by tincanman
- 1043 Views
Last post by Klausc
- 20 Replies
- 4237 Views
Last post by undflyer
- 13 Replies
- 5468 Views
Last post by theobviousfaker
- 5542 Views
Last post by daveyk
